BikeBandit
Closed Thread
Old 06-08-2006   #1 (permalink)
Just rode a 120 miles on the freeway.
Running around a steady 70,according to optimistic speedometer.
The bike is a 2004 Speedmaster.
17T front sprocket.
TBike pipes.
Unifilter drilled along with airbox mod.
Snorkel removed.
130 mains.
Thruxtun needles,no shims.
Side Gapped plugs.
I got a little over 41 mpg.
The bike does run pretty good,but I thought it should get better mileage.
Am I expecting to much?
dowop is offline
Old 06-08-2006   #2 (permalink)
You're right about average from what i've seen in all the MPG posts i've read. thats pretty much exactly what i was getting too. I checked it a few times and was getting about 42. Since i side gapped tho i seem to be up 1-2 MPG, possibly more because i've been riding a it harder since i did it. Tho i also removed a shim about the same time so that could be part of it too. And maybe your thrux needles are keeping you from getting another couple or so MPG. I remember they gave me the richest midrange condition i ever had, tho just a hair more than the TBS w/3 shims. If you ever do try the TBS you may get a bit better, but i'm just guessing.
dazco is offline
Old 06-08-2006   #3 (permalink)
130 mains & 70 mph you were lucky to get that much. I wouldn't complain.
jerry
farky is offline
Old 06-08-2006   #4 (permalink)
Thanks Dazco.
I ordered the TBS needles.
I will give them a try when they get here.
It will be a while as I was told they are coming from England.
The bike does run pretty good with the Thruxtons with no shims though.
dowop is offline
Old 06-08-2006   #5 (permalink)
Jerry,
You are probably right.
The 70mph was probably closer to 65 though.
My bike has a optimistic speedometer.
I guess the mpg is the sacrifice for a nice performance increase.
Thanks.
dowop is offline
Old 06-08-2006   #6 (permalink)
Favorite Bike: 2008 Victory Kingpin
Silverado57's Avatar
Other Motorcycle: 2006 Victory Vegas
Extra Motorcycle: 2005 Speedmaster (Ret.)
My Speedmaster consistently gets 40 mpg with a mix of riding conditions.
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline
Old 06-08-2006   #7 (permalink)
in the interest of better mileage, you could do what some have done and go to a 19 or 18 sprocket
Geoff
I just wanted to ride
Geoff is offline
Old 06-08-2006   #8 (permalink)
Favorite Bike: 2004 Triumph Speedmaster
Extra Motorcycle: 1970 Bridgestone TMX 100
My 790 Speedmaster gets 40-43 mpg on a regular basis - bafflectomy, 125 mains, lower 3" cut off snorkel, stock air cleaner, TBS needles with one shim, AI removed, 17 tooth.
"You can have any color you want as long as it's black!" (Henry Ford) ~ 2004 Speedmaster, modified stock pipes and snorkel, AI removed, K&N filter, 125 mains, TBS needles w/1 shim, 17T. Past Triumphs - '69 650 Bonnie, '78 750 Bonnie.
Ruxtell is offline
Closed Thread
Photos of your Heavily Modded classics MickMaguire Hinckley Classic Triples 25 6 Days Ago 11:08 PM
actual mpg vs computer mpg... airrider03 Sprint Forum 17 10-21-2007 02:31 PM
Freshly modded... FuryFour Triumph SuperSports 15 12-18-2005 04:38 PM
modded stock exhausts? hipporider The Rocket Science Forum 16 12-14-2005 08:14 AM
Modded Speedfour tune. speedfour Triumph SuperSports 7 09-03-2004 11:48 AM
