Old 05-29-2006   #1 (permalink)
To run more stiff or to carry more weight? the manual says to position number 5. Is that the longest tab, making the springs the shortest travel? I would think so but am not sure. Thanks for the help!
"Any day above ground is a good day"
rays323929 is offline   Reply With Quote
Old 05-29-2006   #2 (permalink)
Yes, the stiffest suspension comes when the adjuster is set so the spring is "shortest", i.e. with the greatest preload.
For years I just left them in the middle (step 3) and figured that was close enough for general use, commuting, occasional 2-up, etc. With a light kid on back it's fine, but I noticed with my wife it was pretty spongy so I cranked it up all the way for a 2-up ride, and it really does make a big difference. Then before I set out on a 150miler solo today I cranked it down to "2", and at the end of the day I don't think I felt so beat up.
Now I keep my home-made adjustment tool (a ground down screwdriver) in my saddlebag all the time. It only takes a minute to set it so you are more comfortable.
SmokinJoe is offline   Reply With Quote
Old 05-29-2006   #3 (permalink)
Yes I adjusted all the way to 5 for me and the little lady, and it was a huge difference.
Adjuster for stock TS shock (preload) Mojoinco Hinckley Classic Triples 9 01-12-2007 12:42 PM
Rear Shock Preload. Limey Speed Triple Forum 3 12-23-2006 07:18 PM
Stock rear shock adjustment on 98-01 S3??? Jglisso Speed Triple Forum 2 11-07-2006 07:19 AM
Stock rear shock adjustment question mshelton Club Cafe 6 11-05-2006 10:08 AM
stock rear shock rebound adjustment - 2001 whoa Tiger Workshop 9 03-29-2005 05:08 PM
