Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 11-26-2005   #1 (permalink)
With my bike jetted a fair bit richer as in TBS needles shimmed to shorten them as much as the stock needles with one shim on them and 130 mains, it runs strong. Uni filter drilled airbox and no snorkel.
I've never touched the pilots tho because i've read several times that the pilots rarely need to be changed. It doesn't seem like the lowest throttle positions are suffering but i can't help but wonder if they could be improved. Any educated opinions about this?
Old 11-26-2005   #2 (permalink)
If you're not experiencing any hiccups/stumbling/poor performance I'd leave them alone.
That said I just added D&D pipes to my bike and it's running very well, mileage is even up. On monday I'll be pulling plugs and looking at rejetting the mains, if needed. I don't foresee changing the pilot jets, though I bought a set just in case.
PS the D&D pipes are seriously LOUD!
Bigsteve is offline   Reply With Quote
Old 11-26-2005   #3 (permalink)
Old 11-26-2005   #4 (permalink)
Not that I'm reconsidering...but have you ever heard EPCO pipes? How do they compare on the loudness scale? :brk:
Time flies like the wind...Fruit flies like banannas.
Griles is offline   Reply With Quote
Old 11-27-2005   #5 (permalink)
Daz,
Here's a simple test. Ride the bike in first gear at 2k rpms for about 2 minutes, hold it steady at 2k and if it jerks/stutters, up the pilots a step. If it stays nice and smooth, leave it be. Even with all my mods, I have not needed to swap the pilots out, I tried once for Sheis & Grins and it ran poorly in the idle to 1/8 position.
[ This message was edited by: Dinqua on 2005-11-27 11:33 ]
Pat Whitbeck
Canandaigua, New York 14424
Dinqua is offline   Reply With Quote
Old 11-27-2005   #6 (permalink)
i'll try that. Thanks.
Main Jets & Pilot Jets ggRAT Club Cafe 21 11-13-2007 08:52 AM
Change jets? OGSpeed3 T3 Sport / Touring Forum 10 03-21-2007 10:57 PM
How to change new bonnie jets/needles/shims... derek985 Twins Talk 3 06-03-2006 03:13 PM
Pilot jets Saigon5 Hinckley Classic Triples 3 08-17-2005 07:44 AM
First oil change, gear change still clunky M2MG Speed Triple Forum 3 09-03-2004 12:30 PM
