I believe the 900, 902, or 904--whatever it's called is basically a do it your-selfer. You do have to exchange jugs or get yours bored. I have heard that the kit up around 1000 cc's requires machining on the lower cases for clearance--this would not be classified as a do it your-selfer to me.
I believe Diniqua (SP?) did a 904 kit on his Speedy if my memory is correct. I also believe he is running the CR carbs. Send him a PM.
Larry
Larry
