Motorcycle.com
Old 09-28-2005   #1 (permalink)
i installed my scottoiler tonight, and when i looked for a vacuum port, i found 4 of them, two on each side. one is up close to the intake on the head, where it gets really hot. (in fact the vacuum caps always seem to fall apart when i try to remove them.) the other is on top of the carburetor near the front.
it seems to work.
billyzinc is offline   Reply With Quote
Old 09-28-2005   #2 (permalink)
Billy, I have a Scott oiler on my thrux. I put the tee in the vacuum line off the right manifold. I cut it just behind the right carb. I haven't had a problem with heat.
I have my oiler set on 3 and it still makes a big mess out of the rear wheel. It wipes off easily and i haven't had to adjust my chain yet. I only have 2500 miles on it though and have had the oiler on since 300 miles. I hope this helps out. Vince
If I agree with you, we would both be wrong!! Vinny
azvinny1971 is offline   Reply With Quote
T100. Good Points v Bad Points. UK Daveski Twins Technical Talk 13 08-15-2007 05:59 AM
points of clarification motorcritter Daytona Deliberations 0 09-02-2006 10:53 AM
tt600 vacuum hose for scottoiler? Dabz Triumph SuperSports 2 08-25-2006 05:16 AM
Getting out of points?? Big_Rick Twins Talk 14 07-22-2006 09:52 PM
new points psds Classic, Vintage & Veteran 5 11-04-2005 12:45 PM
