Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
BikeBandit
Old 04-20-2005   #1 (permalink)
I purchased a K&N air filter for my TT. Is it neccessary to completely remove the fuel tank to access the air box? If it needs to be removed, are these fuel connectors that much of a pain (I have the updated connectors). I'm hoping this doesn't turn into a major ordeal.
Also does anyone have any first hand experience with the K&N in a TT or Speed Four? I'm curious if the $49 was worth it.
Thanks,
Schmitty
Black 'cause it's BAD ASS
Some people are like Slinkies...
Not really good for anything,
but they still bring a smile to your face when you push them down a flight of stairs.
Schmitty is offline   Reply With Quote
Old 04-20-2005   #2 (permalink)
Yes, the tank has to be removed, but it's not that much of an ordeal. Some people (myself included) have had problems with the connectors not sealing, but others haven't. If yours don't seal, my advice would be to try and do it with as little fuel in the tank as possible, take some rags and put them between the tank and frame rail on the left side to prevent paint scratching. Lift up the tank from the right side and try to rotate it onto it's side & then pull out the connectors. Also if you have some kind of container that you can place under the tank connectors in the engine compartment to catch any spills, it might be a good idea.
Zane
2003 Triumph Speed Four
2006 Honda RC51
zaner30 is offline   Reply With Quote
Old 04-20-2005   #3 (permalink)
Hey Schmitty!
Where'd ya get the K&N from? Is it just the same flat paper filter like the stock?
And yes, I too have the new gas tank connectors and they leak 2 times out of 3 that I've removed the tank. It ain't a big deal, just sloppy.
Because they're fast!
MadMark is offline   Reply With Quote
Old 04-21-2005   #4 (permalink)
Hey Mark,
I ordered it from my local dealer. No it isn't a paper filter like the stocker. It is oiled, pleated, cotton gauze. It's supposed to flow more air with the same or better filtration properties. It's also washable and reusable and comes with a 10 year/1 million mile :razz: warranty. Its supposed to add power without any fuel remapping. Time will tell though.
Old 04-22-2005   #5 (permalink)
Let us know how it works, I need a new one and I've been thinking about the K&N.
coastie is offline   Reply With Quote
AI Install Redrider736 Modifications & Workshop Talk 6 11-20-2007 01:33 AM
TT600 Oil Filter (Triumph OEM VS. K&N Oil Filter) spin Triumph SuperSports 14 06-11-2007 11:49 PM
Problem with airbox removal and K&N filter install junabug Club Cafe 11 11-10-2006 10:37 PM
GPS install? Martini Triumph SuperSports 8 10-07-2005 06:39 AM
Fuel Filter/oil filter/oil type Anchorbend Twins Talk 4 07-24-2005 01:00 AM
