Progressive Insurance
AmericanMotorcyclistAssociationbritishcustomsAdvanstarMotorcycleShowsShopTriumph.comMotorcycle.comAnnitori DistributingBikeBanditSpringfield ArmoryCycleGear.comMotorcycle.com Classifieds!
SportbikeTrackGear
Old 04-16-2005   #1 (permalink)
Favorite Bike: 04 Speed Four
Other Motorcycle: 71 BSA Lightening
Boy I tell ya what a day...... I try to get my bike inspected and because one of my two headlights was out they wouldnt pass me.... because the nearest Triumph shop is 2-3 hours away I have to try to figure it out myself..... I posted a thread earlier amidst some frustration...... now I have narrowed the light problem down to the wiring harness but the problem is that when I try to take my tank off the "white" fuel connector is leaking fuel like crazy...is this normal??? I disconnect the red and all is fine. When I disconnect the white the gas just keeps on pouring out... am I doing something wrong???? I push the metal button back in and it still leaks... any ideas???? I am trying to avoid a 2-3 hour trip for something that I may be able to do myself.... Thanx for any help you can throw my way......
tridrill is offline   Reply With Quote
Old 04-17-2005   #2 (permalink)
timmmy
it shouldnt be leaking when its disconnected,sounds like the connector is faulty,i take it it doesnt leak once its reconnected
Old 04-17-2005   #3 (permalink)
Both of my fule connectors leak form the tank when disconnected. As they do not leak when assembled (and the recall replacement repair has been done) my dealer will not change them.
If it does not affect the running of the bike you just need to ensure the tank is low before you remove it and when it is off prop it up nose down.
Jon
Old 04-17-2005   #4 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
Yeah, the new fuel connectors leak a bit. The old ones didn't. I guess you can have connectors that don't leak or fuel connectors that don't break. Take your pick.
Will
SponsorHouse profile
Old 04-18-2005   #5 (permalink)
I have the new connectors and they don't leak. I pulled the tank off this weekend to check the valves and didn't have any leakage even though the tank was about 2/3 full.
keithu is offline   Reply With Quote
Old 04-18-2005   #6 (permalink)
Old 04-18-2005   #7 (permalink)
OK....another question.... the rubber orings on the male portion of the fuel connector.... is it a common automotive part or is a Triumph special order?????
Old 04-18-2005   #8 (permalink)
Old 04-19-2005   #9 (permalink)
Tridrill
If you have sliced one whilst putting the connectors together sometiems you can get away with reversing it so the torn flap is on the other side. Good luck
Jon
Old 04-20-2005   #10 (permalink)
On mine it's the red one that leaks when disconnected.
coastie is offline   Reply With Quote
GETTING GAS TANK DOWN? dblhelx Speed Triple Forum 1 07-08-2007 09:33 PM
tank rack, locking gas cap, tank bag GleaminTwin Twins Talk 6 08-03-2006 09:29 AM
Old gas in the tank need help... Darkness Modifications & Workshop Talk 3 07-21-2006 06:10 AM
ST gas tank????????? ronniena Sprint Forum 4 06-20-2006 12:36 PM
different gas tank? motothrux Twins Talk 1 11-07-2005 01:36 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
