Motorcycle.comTrident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
Old 07-06-2008   #1 (permalink)
Newbie
Headlight bulb replacement
I apologize for this question in advance for how stupid it may seem. My low beam headlight died the other day and the service manual i have says i need to dismantle my whole cockpit remove the whole headlight assembly just to change the bulb, is this really neccesary. I figure ishould be able to reach in at it unhook the wire harness and twist. also how much effort is needed to unhook the harness i tried already but with my luck i stopped before i broke something?
whingst is offline   Reply With Quote
Old 07-06-2008   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
What bike? On a TT600, you absolutely don't have to take everything apart. It is a bit of a pain to get at the back of the light, but you can do it without taking much of anything apart. Other models, I am not so sure.
Will
SponsorHouse profile
Old 07-06-2008   #3 (permalink)
Newbie
ya it is a 01 TT600. so how much effort should it take to undo the harness on the back of the headlight assembly
Old 07-06-2008   #4 (permalink)
Will's Avatar
Not much. You just pull back the boot, undo the clip, pull out the assembly, change the bulb, and put it all back. It is fiddly, but it isn't tough. I don't remember if you have to unplug the bulb before you pull it out or not.
Will
Last edited by Will : 07-06-2008 at 10:17 PM. Reason: Nope, I don't know it all! I forgot most of it by now.
Old 07-06-2008   #5 (permalink)
Newbie
thank you for the help, the manual i have makes it sound a whole lot more complicated. while on the topic of headlights is there any brand of HIDs anyone would recommend for the 600TT
Old 07-07-2008   #6 (permalink)
Will's Avatar
Just a PIAA superwhite or similar bulb. There's no reason to go up in wattage if you use one of the superwhite type bulbs. They are a little more expensive, but they let you see.
Will
Old 07-07-2008   #7 (permalink)
Vankaye's Avatar
I have the exact same issue and have been running with my high-beam.
My current lite has a little bit of a green/blue tint and is extremely bright.
Anybody know what type of bulb this might be? I kinda like it and would like
to find a replacement bulb that will do the same.
Vankaye
Vankaye is offline   Reply With Quote
Sprint St 955i Headlight Bulb Replacement RonnieD155 Sprint Forum 10 08-15-2007 02:50 PM
Headlight Bulb Replacement? - 05s and up jdscott74 Sprint Forum 3 05-10-2007 10:31 AM
replacement headlight bulb ORCA Speed Triple Forum 1 03-22-2007 05:41 AM
Advice on Headlight Bulb Replacement Options TripleThreat Speed Triple Forum 10 12-02-2004 05:24 PM
Headlight bulb replacement PeterB Hinckley Classic Triples 2 04-18-2004 03:54 PM
