BikeBandit
Old 03-28-2005   #1 (permalink)
My TT600 is running poorly and keeps stalling at junctions,it is a 2000 model and has the new type cams fitted also the crossover pipe has been done and it is the official Triumph aftermarket loud exhaust . My dealer says the throttle bodies need balancing. New to this site which is very good , I think it is time to bite the bullet and have a go tuning the bike myself. My intention is to buy TUNEBOY which I believe may have a function to balance the throttle bodies if they are not out to far. If that doesn't work I will need to balance the throttle bodies manually. What do I do about setting up the CO? I live in the UK where is the best deal on TUNEBOY?and what do I need to balance throttle bodies, and the CO?Thanks for any advice.......
MarkTheBike is offline   Reply With Quote
Old 03-28-2005   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
There are two issues here. Synching up the throttle bodies is mechanical rather than electrical. Think of synching carbs. You use similar equipment for both. Tuneboy won't do it. There is only one place to get the cable and unlock codes you need for Tuneboy. That is Wayne MacDonald's website in Austrailia. TuneBoy Website Once you have it, treat your bike as an '01 since it has the '01 update from the factory. Several of us have tunes that we have played with for different years of bikes.
Will
SponsorHouse profile
TORS tune from dealer or Tuneboy tune? Max_NYC Speed Triple Forum 25 07-06-2007 10:22 PM
anybody here using the tuneboy and if so what tune do you like king4456 Daytona Deliberations 9 04-10-2007 12:18 PM
tuneboy tune edit compatibility ?? mongo Speed Triple Forum 11 03-17-2007 02:12 AM
TuneBoy tune questions RandyL Sprint Forum 1 05-07-2006 05:42 PM
