Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.comBikeBandit
Old 06-01-2008   #1 (permalink)
Unhappy 911 i need help tt rider blowing smoke
i was riding my 2001 tt600 to work early friday morning around 40 degrees out and about half way to my job the bike started blowing out oil through my exhaust. It was heavy burnt smoke do to the oil burning up in my exhaust but the bike was cool around 185 and fresh oil and coolant still left in their resivours. No real ticking in the values and the bike was running smooth so i dont think it is the top end. 911 i need your help on potential ideas before i dare bring it to a bike shop and get raped on diagnostic fees. Thanks rats any reponses would help me sleep easier tonight.
kevstt6 is offline   Reply With Quote
Old 06-01-2008   #2 (permalink)
Favorite Bike: 2003 Triumph Daytona 955i
ga_skyline_rydr's Avatar
Other Motorcycle: 1993 Honda XR 650 L
Originally Posted by kevstt6 View Post
i was riding to work early friday morning around 40 degrees out and about half way to my job the bike started blowing out oil through my exhaust. It was heavy burnt smoke do to the oil burning up in my exhaust but the bike was cool around 185 and fresh oil and coolant still left in their resivours. No real ticking in the values and the bike was running smooth so i dont think it is the top end. 911 i need your help on potential ideas before i dare bring it to a bike shop and get raped on diagnostic fees. Thanks rats any reponses would help me sleep easier tonight.
How many miles are on the bike? Some how or other oil is getting past the valves and rings and getting into the combustion chamber out the exhaust. Have had the oil changed recently? Also how did the coolant look, how did the oil look? Let us know.
ga_skyline_rydr is offline   Reply With Quote
Old 06-01-2008   #3 (permalink)
reply
the bike has around 10500 miles and the oil and filter has been replaced 1500 miles ago. As far as oil that is left in the engine it is clean, but as far as what is comming out the exhaust dark black burnt oil. I havent flushed the coolant or anything but what is in the resivior is clean. I do need to replace the air filter however i dont think they would be related
Old 06-01-2008   #4 (permalink)
Bomboderator
Favorite Bike: '00 Speed-TT
BombFactory's Avatar
Other Motorcycle: '02 CE Speedtona 955i
If the smoke coming out of the exhaust is black then it is not oil, it is fuel. Black/Charcoal smoke is the sign of a rich running condition, while blue-gray smoke is oil, and white smoke (actually steam) is water/coolant. There could be a couple different causes of this. First off, what gas did you last put in the bike? You could have possibly gotten an old batch of gas if you went to a cheaper station, or is there any possibility that you mistakenly put any diesel fuel in the tank? What kind of ECM map do you have loaded? If it is a performance-type map then you could have major carbon buildup that is now blowing out. You might try running some fuel injector cleaner or SeaFoam in the gas to see if that will clean things out. If you use the bike as a commuter and rarely give the bike a good thrashing on twisties or straight-aways, the cylinders and head can become carboned up.
Aside from those possible causes it could be due to a malfunctioning Air Temperature sensor, or ECM. Judging from the mileage on the bike I would think it is not due to these parts, but it could be.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
Project Straight-Line: The TT600 Drag Bike
The philosophers have only interpreted the world, in various ways; the point, however, is to change it. - Karl Marx
BombFactory is offline   Reply With Quote
Old 06-04-2008   #5 (permalink)
not sure about carbon build up
everytime i ride my bike it typically sees alot of abuse in all 4 seasons of the year so i could rule the carbon build up out. Definately not fuel related, but still some how it is pushing past my values and the oil is not being contained inside my engine. Thanks for the help. I still need more if anyone has other ideas
Old 06-04-2008   #6 (permalink)
I don't mean to be a nut case here, but by chance do you stand the bike up. What colour of smoke are you seeing and how do the plugs look?
Old 06-07-2008   #7 (permalink)
Favorite Bike: 07 Blue S3
BBDGriptonia's Avatar
Other Motorcycle: 97 Bandit - Sea Bass
Also check that breather tube. Just disconecting from air box and looking for fresh oil is easy and fast.
If you still can't find a reason, and you seem quite positive its not a fuel issue (i was leaning with Bomb on that one) get a compression check or Leak down test done. If the oil is getting past the rings, thats the number one reason for burning smoke, the test will help diagnose the problem.
Start the bike up, and once the smoke is coming out pretty thick, stick your hand in it for a moment, then smell. Fuel and oil have two very distinct scents.
If its fuel, i would check the mapping (weird it would change for no reason). Another one would be exhaust valves not closing all the way, and excess, uncombusted fuel burning off in the pipe causing the smoke and delicious smell. Another issue that would be identified via compression test.
Hope that helps!
"Dream like you'll live forever. Live like you'll die today."
James Dean
BBDGriptonia is offline   Reply With Quote
Old 06-08-2008   #8 (permalink)
i think we are on the right check
doing the compression test is where i am going to start off. I think you are right in the sense it could be a ring around the pistion where it is a compressioon ring or oil ring. Anyways i am a diverse rider and like to pull up the front up but typically i can only ride the wheelies out for less than a mile. Then agian the bike does see endos from time to time how do you think these two can be related? I hope to figure this out soon so i can get back out there with you guys but i think we are finally on the right track. THNX BROS. oh yea and the only reason the bike was actually smoking was from the fresh oil hitting the hot exhaust headers and then burning out my tail pipe
Old 06-08-2008   #9 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
Riding long wheelies will starve the top end of oil. Less than a mile is a whole lot longer than a brief wheelie from acceleration, so I would be concerned about oil starvation issues and your valves.
Will
SponsorHouse profile
Will is online now   Reply With Quote
Blue Smoke... dkurtz Triumph SuperSports 13 04-09-2007 09:03 PM
Smoke IainG Speed Triple Forum 1 05-12-2006 03:46 PM
Carburettor Smoke woodchuck Twins Talk 2 03-30-2006 08:06 AM
WHITE SMOKE!!!!! HELP!!!! MeshMan Triumph SuperSports 5 07-11-2005 08:06 AM
smoke any gixxers dragline708 Daytona Deliberations 37 02-03-2005 07:39 PM
