BikeBandit
Old 05-17-2008   #11 (permalink)
I probably need to have my codes checked also. My 01 does the same stalling trick, much less now than when I first bought it last year. I put new plugs in this spring but it still happens occasionally. This typically only happens while the clutch is held in while slowing down.
It's very occasional for me though, perhaps five or six times in the last 1000 miles.
Mike
01 TT600
GTiPilot is offline   Reply With Quote
Old 05-17-2008   #12 (permalink)
Favorite Bike: 2001 Triumph tt600
Triumphant600's Avatar
If you have a Power Commander what is it reading? Your map might need some re-mapping...
Zac
How about we play a game called "just the tip" just for a minute, just to see how it feels? - Vince Vaughn
Triumphant600 is offline   Reply With Quote
Old 05-17-2008   #13 (permalink)
Favorite Bike: 2000 TT600
Other Motorcycle: 1997 Katana 600
I noticed that with my bike engine off but with the key turned on and the kill switch on my PCIIIUSB read that my throttle was at 6%. I'll try resetting that to 0 and see if that helps. Here is the map I have on the bike (the way it was from the previous owner). I have a Scorpion exhaust and I supposedly have a K&N filter but I honestly have not even checked that out yet. The bike was supposedly dyno tuned by the previous owner, I am not sure on the validity of this claim but the bike has been running great until recently.
'00 TT600
'87 GN
GNTurbo6 is offline   Reply With Quote
Old 05-18-2008   #14 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
There's not a lot of performance difference between a K&N filter and a stock filter, so it doesn't matter.
I don't remember if anybody mentioned looking at the various vacuum hoses to make sure they are all properly connected. Also, make sure there are no unplugged holes in the airbox downstream of the filter.
Will
SponsorHouse profile
Old 05-19-2008   #15 (permalink)
Favorite Bike: Daytona 650
How would you go about readjusting the TPS sensor or throttle position? I am having EXACTLY the same problems with my daytona 650, you can look at the previous thread about it below titled 'Daytona 650 dies at idle'. I ran lucas injector cleaner through four tanks as well as completely cleaning everything out, oil, filters, new plugs, etc. I HAVE however given it throttle at startup to try and get it to fire up, so I am sure that my TPS is out of whack. Help!
Evanman48
Evanman48 is offline   Reply With Quote
Old 05-19-2008   #16 (permalink)
Evanman48, your TPS sensor is probably located at the end of the throttle cable on the engine side on/near the throttle bodies. To adjust it you probably have to check the wires/contacts with a multimeter for an ohm reading and then physically adjust it so that it falls within a certain spec. Sorry I'm so vague on this but I have yet to do it on my bike but I have done it on my car.
I reset my PCIII USB's throttle position yesterday, like I said it was reading 6% when completely off the throttle. The throttle position reading was at about 5500 (I'm not sure what measurement this is) and the baseline 0% was like 4750 so my TPS sensor may need an adjustment as well.
Anyway so far I haven't had it stall on me but I have yet to ride under the same weather conditions as when it was happening. I'll keep my fingers crossed.
'00 TT600
'87 GN
stalling yakoo11 Triumph SuperSports 4 04-23-2008 10:39 PM
'03 S3 Stalling mussoorie Speed Triple Forum 0 07-31-2007 02:11 PM
stalling zigzag5555 Speed Triple Forum 3 06-01-2006 08:06 AM
Stalling T-509 ST Modifications & Workshop Talk 19 09-01-2004 12:21 PM
Stalling? Triumph SuperSports 7 08-29-2004 12:22 PM
