another way to check to see if you have fuel pressure... a pretty easy way... (not the safest, but I found out about this when I was connecting my fuel tank) Plug up the tank to the fuel like, prime the fuel pump (turn on the key and ign, but don't start it) and try to move the fuel hose around (try not to disconnect it!)
I forgot to put the hose clamp on mine, I noticed it was halfway off and as soon as I tried to slide the hose more onto the metal connector, fuel came spraying out on all sides. Turns out, it's pretty easy to find out if you have fuel pressure. Mind you, I just started my bike with 6 month old fuel and no radiator or coolant in it while it was throwing three codes.
I have a couple extra connectors, can't figure out what they go to yet, but I'm sure they'll surface soon. Does the bike crank? I've discovered that there's no codes that will cause your bike not to crank.
If you can pull codes, a couple free triumph manuals are here
http://www.carlsalter.com/motorcycle-manuals.asp which may help you, they're a little older and a different model, but the fuel injection systems are the same. I'd pull the plugs and give them a read.
Note: A buddy of mine's jetski wouldn't start, I looked at the plugs and they looked fine. Cranked and cranked and cranked, tried starting fluid. Nothing at all. Replaced the plugs, fired right up and ran 60mph no problem. Sometimes it's just real simple.
Oh, PS. Another way to find out if she's getting fuel (figured this one out on the Jetski too.) Pull the plugs, crank her over with the plugs out. If you get fuel mist out of all the cylinders, you're getting fuel. (mind you, with his jetski, it almost blinded me from three feet away - yamaha something or other. but with my honda f12x, barely any mist came out, but still enough that I knew the injectors were firing.
