» Log in
User Name Not a member yet?
Register Now!
  #11 (permalink)
Old 1 Week Ago
BombFactory's Avatar
Will, you're correct on the different rotors for the liter Daytonas and S3's. If I recall correctly, the larger bikes are a 5 bolt pattern as apposed to the TT600/S4/D600/650 6 bolt. The dish backspacing might be different also. Also, you would have to find a wheel that used a rotor of the same or close to the same diameter, else you will have to do some sort of spacing out or in of the Triumph calipers (in being impossible). Another thing to remember is axle diameters. Although if the difference between one make's axle size to the TT600/S4/D600/650 20mm axle is only 1 or 2 mm, different bearings might suffice. However, like some GSXR wheels, the 25mm axle just won't jive well with 20mm holes in the Triumph forks.
The loss of the stock speedo and the need to build a spacer will definitely present another issue. Unless you have a lathe and mill, or know a machinist who will work for cheap, or have a fat wallet to pay a machinist who won't work for cheap, the task of swapping different make wheels onto a TT600/S4 would seem daunting and too expensive to me--not to say it can't be done.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
Project Straight-Line: The TT600 Drag Bike
The philosophers have only interpreted the world, in various ways; the point, however, is to change it. - Karl Marx
  #12 (permalink)
Old 1 Week Ago
Favorite Bike: 00 TT600 Red/Silver
Other Motorcycle: 04 Yamaha YZ450f
Extra Motorcycle: 00 Buell X-1 Lightning
Captive spacers? If the bearing size is that far off, this would probably make the most sense wouldn't it? You are going to have to make spacers anyway.
The reason Santa is so jolly is because he knows where the naughty girls live.
  #13 (permalink)
Old 1 Week Ago
X1wagner, good point on the captive spacers. In my opinion, finding a direct fit wheel bearing to go from 'x' OD to a 20mm ID would be easiest as far as machining spacers goes. You'd just need 20mm ID spacers to get the wheel centered.
  #14 (permalink)
Old 1 Week Ago
I'm with you, I was just pointing out that this is a great opportunity to not have to shove spacers in your wheels when you're mounting them up.
Then you could go endurance racing.
  #15 (permalink)
Old 6 Days Ago
mahuez's Avatar
so then where can i get aftermarket wheels for the tt?
<a href=http://www.mybannermaker.com/link.php?nurl=http%3A%2F%2Fwww.mybannermaker.com target=_blank><a href=http://img260.imageshack.us/img260/9272/mybanner481a17b35beb7wk2.jpg target=_blank>http://img260.imageshack.us/img260/9...b35beb7wk2.jpg</a></a>
  #16 (permalink)
Old 6 Days Ago
I think the trick is that you can't.
That doesn't mean that you couldn't cobble some together with enough $, time and machining skills. Probably a combination of all 3. There aren't any after market wheel choices for for the Triumphs so yours would have to come from some other bike or some other bike's application. If you follow the link, there is a comparison of wheel brands, it may help you in your quest.
http://www.sportrider.com/sportbike_...son/index.html
Josh
Carrozzeria Wheels vs wire wheels MAR Club Cafe 7 10-28-2007 11:07 AM
Wheels rickster Daytona Deliberations 3 06-28-2007 12:21 AM
Wheels Spudgun Tiger Workshop 2 08-08-2006 07:05 AM
mag wheels sweatmachine Triumph Twins HangOut 13 08-07-2006 09:22 PM
Bad wheels --- The Rocket Science Forum 6 10-15-2005 06:40 AM
