Motorcycle.com
Old 05-03-2008   #1 (permalink)
Fun with chain rub strip and clutch cable...
well it's finally on. had to get a new rear tyre so ideal time to get the new rub strip in and it's no exaggeration- a day of spitting swearing plently of grease and a rubber mallet. but it's now done!!! plus a hefty wad of cash saved on taking it into the shop.
the old one was a 'new' type- the harder strip so it was a cut out job to remove.
next on the list is replacing/rerouting the clutch cable which is wearing. i'm getting wear on the part of the sleeve that rubs on the retaining bracket.
anyone know off hand what a new stock cable goes for? if i remember the venhill cables were around £25 plus they eliminate the elbow.
johnnycactus is offline   Reply With Quote
Old 05-03-2008   #2 (permalink)
OK, I give, I'm new to the S4 and I've been reading about people having horror stories with the 'rub strip', exactly what is the problem and why is it such a massive deal? TIA
skiTTles is offline   Reply With Quote
Old 05-03-2008   #3 (permalink)
If you do the replacing by the book you're supposed to take the fork off the bike, but that's not really ncessary.
FART FYRA
pete2 is offline   Reply With Quote
Old 05-04-2008   #4 (permalink)
yeah, its basically a rubber strip that runs along the top and bottom of the swing arm. you can see it on the l/h side where the chain dissappears to the front sprocket. you'll also notice how small a gap there is between the frame and swingarm!
but it can be done! its also alot cheaper than going to a dealers and spending a fortune.they will take the swingarm off to replace. it ain't a cheap procedure for a £20 wearing part!
'00 RS Clutch Cable MrMoped Sprint Forum 5 09-01-2007 05:32 AM
trying to replace the chain rub strip on my TT HELP ? Loun Triumph SuperSports 6 07-22-2007 07:39 PM
TT600 Chain Rubbing Strip MarkTheBike Triumph SuperSports 11 04-24-2007 03:20 AM
Rubber chain strip Dingle Triumph SuperSports 10 03-24-2007 12:57 PM
CLUTCH CABLE ricster Sprint Forum 3 01-18-2007 12:59 AM
