Old 05-02-2008   #1 (permalink)
How to properly set my Power Commander
I have a k&N filter, and a slip on Yoshimura RS-3 exaust on a 2003 TT600. I picked up a power commander (serial not usb) for $100. Now I want to properly map my bike. I downloaded the maps off dynojet's website, but have know idea which one to use, or how to best tune the bike.
I currently set the bike to a 0 map.
-bj
p.s. I don't have money for a dyno tune, but wish i did.
wileytt is offline   Reply With Quote
Old 05-03-2008   #2 (permalink)
Sry, you'll need a dyno tune.
FART FYRA
pete2 is offline   Reply With Quote
Old 05-03-2008   #3 (permalink)
Newbie
Favorite Bike: 2003 TT600 caspian blue
Shaun's Avatar
Willeytt,
I have just fitted the usb version to my 2003 TT600 (UK) and am a bit in the dark too. Dynojet will tell you that their map will further optimize the stock settings, in fact Dynojet UK tell me that a PC will 'transform' my bike. There is a map on the USA site for a K&N or stock air filter with a micron slip on can. I think this would be your starting point. I checked at my local dyno yesterday and they do say no 2 bikes are the same and each should have a dyno run and a custom map.
Interestingly I fitted my PC last night, it all powers up okay but the bike would not start with the PC connected? Disconnect and it starts perfectly. Sent it 3 different maps, zero, stock, and the one above and no difference. All connections seem okay. Got late so I am going to have another look today.
Anyone have any ideas??
Shaun
Shaun is offline   Reply With Quote
Old 05-03-2008   #4 (permalink)
Favorite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
The three maps from power commander are a blanket fix.none fix the programing perfectly, but are close. I'm riding a 2000 TT.
When I had the Micron pipe/k&n filter combo on I had to sit down and made "my own map" by useing the first 1/2 of map #2 and the second 1/2 of map three. Because the filter/pipe madean already large flat spot worse from 3000-4000 rpm that I could not cure. Some day I'll get it on the dyno (lack of $$$).
But at the moment I have the stock pipe back on (Micron needed rebuild) w/ map #2 and it runs great, plus most of the flat spot is gone.
Save yourself a headache, put it on the dyno and get a cusot map as soon as possible.
kubbie is offline   Reply With Quote
Power Commander sirreal187 Speed Triple Forum 9 01-30-2008 06:08 PM
Who actually has a Power Commander? R100Pilot Speed Triple Forum 27 08-08-2006 09:06 AM
05/06 ST Power Commander?? silverflash Sprint Forum 3 03-29-2006 01:15 AM
Power commander LOWEY Triumph SuperSports 9 01-25-2006 05:02 AM
Power Commander Q?'s ejmoment The Rocket Science Forum 10 07-09-2005 11:28 AM
