Motorcycle.com
Old 05-02-2008   #1 (permalink)
One thing after another. please tell me im doing this right!
my bike was running lean. so i chnaged the fuel filter.then it was just dumping fuel so i tried the pressure regulartor. now its pull codes for the fuel injectors and fuel pump. is the fuel relay next? i have order the metal connections for the fuel lines cause mine are sticking or just messed up. any other ideas on stuff i need to fix for the fuel problem?
All this cause some dumbass didnt know how to maintain the bike!!
freshusmc is offline   Reply With Quote
Old 05-03-2008   #2 (permalink)
Favorite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
Man , you got all kinds of problems.
First off where is it leaking fuel from? Tell us that, then we can work out some answers for your other problems.
kubbie
kubbie is offline   Reply With Quote
Old 05-03-2008   #3 (permalink)
oh its just from the plastic disconnects on the bottom of the tank and i got the metal ones on order. do you think i have a bent vavle or something?
Old 05-03-2008   #4 (permalink)
i mean as far as the running problems?
Old 05-05-2008   #5 (permalink)
kubbie's Avatar
what exactly are the codes its throwing?
if you don't have a code reader, you could go to autozone and see if they'll retrieve them for you.
real quick, did you turn the ignition to run w/ the tank off or anything unpluged? it will throw codes for that. 3 heat cycles (cold start to fan comes on) will usually clear them.
keep me informed.
kubbie
Old 05-05-2008   #6 (permalink)
Favorite Bike: 00 TT600 Red/Silver
Other Motorcycle: 04 Yamaha YZ450f
Extra Motorcycle: 00 Buell X-1 Lightning
can you get codes from autozone? I thought Triumph used the OBDII connectors, but not they software system that would throw the correct codes. I'm probably wrong.
As for your leaky fuel, it's not leaking around the base of the fuel pump is it? You put the fuel hoses back on the correct sides right?
Metal fittings should help some of your problems.
The reason Santa is so jolly is because he knows where the naughty girls live.
x1wagner is offline   Reply With Quote
Old 05-05-2008   #7 (permalink)
it was throwing the fuel pump and injectors short circut codes
Old 05-05-2008   #8 (permalink)
I've never seen that. Your fuel pump isn't shot is it?
Old 05-05-2008   #9 (permalink)
ok i just checked the codes again and it also pulled up 2 fuel pump relay codes. so i should start there right?
Old 05-05-2008   #10 (permalink)
It's as good a place as any. Check your voltage in and out.. might just be a fuse or a fusable link.
If it's not one thing....... 2ManyToys T3 Sport / Touring Forum 4 05-01-2008 09:11 PM
What is this thing? Hartless Tiger Chat 2 06-08-2007 07:46 PM
One thing after another boidorama Hinckley Classic Triples 5 04-24-2007 05:30 AM
Too much of a bad thing lately....(Another One) RedNeck-Rat Speed Triple Forum 14 10-19-2006 02:17 AM
Just one more thing baldy Club Cafe 2 06-02-2006 09:06 PM
