What other parts? i just dont want to have to buy the harness, ecm and intake since it will cost me a lot more...
I need a direct drop in motor!
The internals are the same, whats the difference between these engines really? are all the connections the same?
Edit: Everything internal about the engine specs out just the same, the only difference that i can see is the cams as already stated.
S4 In. lift=7.7mm VS. TT600 In. lift=9.0mm
S4 Ex. lift=7.8mm VS. TT600 Ex. lift=8.0mm
