Ah, I get it now. Of course, if the engine specs are the same and you match the ECU to the cams, it'll run just like factory. However, I would assume that the TT600 ECU cannot correct for a/f ratios very far out of factory specs, especially due to there being no O2 sensor. Same for the S4, if there is no Lambda sensor.
