Motorcycle.com
Old 04-28-2008   #1 (permalink)
Question tt600 electrical problem
my bike wont start and its an electrical problem. the head lights turn on, the lights on the display turn on, but the mph, miles and the check engine and oil lights dont light up also the fuel pump doesnt turn on and nothing happenes when you press the start button. i thought it was the starter solenoid so i replaced it, that didnt work. i tested the fuses with a test light and fuses 1,2,3,4 have power going to them but 5,6,7,8,9,10 dont have power going to them. does the bike have to be on for them to work? i need some help with this one, here is the tt600 manual mabye one of you can use this. http://www.scribd.com/doc/1014488/Triumph-TT-600-03
thanks,
gary.
gary01tt600 is offline   Reply With Quote
Old 04-28-2008   #2 (permalink)
Favorite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
gary,
1,2,3,4 are hot all the time.5,6,7,8,9,10 are only hot w/ the key on.
gotta ask. Is the kill switch in the run position, bike in neutral w/ the side stand down, and pulling the clutch?
If yes to above my guess would be bad connection to the battery. unhook the battery, make a funny face at it ,put it back together again and see what happens...
let us know if it does/doesn't work.
kubbie
kubbie is offline   Reply With Quote
Old 04-28-2008   #3 (permalink)
i have disconected my batt. and hooked it back up again, normaily when you turn the key to on with the kill switch on, the mph, miles, and the temp.and fuel pump should turn on. in my case, it doesnt.
Old 04-29-2008   #4 (permalink)
kubbie's Avatar
have you had the tank off? maybe, just grasping here , forget to plug in/not fully plugged in fuel pump/sending unit.
did you do any work to bike before this happened?
kubbie
TT600 Electrical Short Cecile Triumph SuperSports 4 04-07-2008 05:28 PM
Electrical problem take 3 mipstien Triumph SuperSports 0 06-10-2007 08:30 PM
TT600 electrical question.. MickyC Triumph SuperSports 6 03-17-2007 06:21 PM
HELP!!!-electrical problem! BassNote Modifications & Workshop Talk 3 06-23-2006 11:01 AM
Need help w/ electrical problem Robert135 Trophy 3 07-14-2005 06:57 PM
