Daytona 600 won't start - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 04-19-2017, 08:07 AM Thread Starter
Newbie
Hi Everyone, I purchased a 2004 Daytona 600 last fall. Love the bike and it was running great when I parked it for the winter. This spring I popped a new battery in there and she won't start for me. When I turn th ignition on I hear the fuel pump prime and then a series of buzzes that I believe is coming from the left side of the bike just underneath the air box. I have seen a few other people with similar issues across the web but haven't been able to find a post where they found the answer. I will be taking her to the shop next week if I can't figure it out. I am slightly mechanically inclined but don't know that much about bikes. Thanks for any insight!
djbalts is offline
post #2 of 7 (permalink) Old 04-19-2017, 08:36 AM
Main Motorcycle: Daytona 600
andrewed1's Avatar
Extra Motorcycle: XJ600s - Project
1. Is it out of gear
2. Turn the kill switch off
3. Turn ignition on
4. Pull in clutch while starting
Sent from my SM-N910G using Tapatalk
andrewed1 is offline
post #3 of 7 (permalink) Old 04-21-2017, 07:59 AM Thread Starter
Newbie
3. Turn ignition on
Yep, I did all of those things, the bike will turn over but won't pop at all, I think it has to do with an actuator or sensor or something that is just below the air box on the left side. I'm wondering if anyone can confirm what that part is and, if it is failing, would it cause what I am describing.
It's a small piston that seems like it's trying to move up and down. Based on the diagram I'm assuming it's the "stepper motor assembly".
When I first turn the ignition on I hear the fuel filter prime and the the part I am describing buzzes repeatedly. Sometimes it stops at four buzzes, sometimes it does more than that.
djbalts is offline
post #4 of 7 (permalink) Old 04-21-2017, 10:56 AM
Official Leathers Tester
Main Motorcycle: Very fast 675
Will's Avatar
Other Motorcycle: DRZ 400 Bad Idea
Dumb question - is the battery fully charged?
Will
Will is offline
post #5 of 7 (permalink) Old 04-21-2017, 10:42 PM Thread Starter
Newbie
Yep, bought a brand new one and charged it up this spring.
I'm gonna try to get it into the shop tomorrow. Hopefully they can figure it out. I'm much better with the carbureted bikes than these fuel injected ones
djbalts is offline
post #6 of 7 (permalink) Old 04-22-2017, 08:59 AM
andrewed1's Avatar
Is the fuel pump actually pumping fuel?? Have you disconnected it from the rail and test.
Next if it is pumping fuel is it at the correct pressure??
post #7 of 7 (permalink) Old 04-22-2017, 09:16 AM
Will's Avatar
Another thought is to check for a clogged up fuel filter.
Will
Will is offline
Daytona 600 tail tidy jenson10 Triumph SuperSports 13 01-16-2017 08:52 AM
Daytona 600 '04 won't turn over and start willh92 Triumph SuperSports 11 09-26-2015 11:45 AM
Daytona 600 starting issues Phillym Triumph SuperSports 22 04-16-2015 10:52 PM
Help! Daytona 600 map in TuneECU which one? KnobHead Triumph SuperSports 2 03-22-2015 06:42 AM
2004 Daytona 600 R/R upgrade DaytonaWMR Triumph SuperSports 3 02-12-2015 08:57 PM
