Old 04-07-2008   #1 (permalink)
Newbie
Favorite Bike: TT 600
Other Motorcycle: 83 Honda Saber
Extra Motorcycle: I wish
TT 600 Air Sensor
While doing maintenance on my bike I noticed that there is no air temperature sensor connected to the air box. I have tried to find info on this sensor, but haven't had any luck. All I have found is an electrical cable that isn't connected to anything. Are some bikes shipped without these sensors, something like an "optional" part?
Any suggestions?
NSTriumph is offline   Reply With Quote
Old 04-07-2008   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
Is the connector you found gray? If so, it is part of California emissions equipment and doesn't do anything in the rest of the world.
Will
SponsorHouse profile
Old 04-08-2008   #3 (permalink)
does it do anything when you connect it? or is it just to pass the test and it virtually does nothing?
Justice Strike is offline   Reply With Quote
Old 04-08-2008   #4 (permalink)
Favorite Bike: 07 Blue S3
BBDGriptonia's Avatar
Other Motorcycle: 97 Bandit - Sea Bass
They wont be able to connect the cable if bike has swapped motors, or even swapped ecu and wiring equipment. My 01 did have a connector to the airbox, but the 00 engine i got out of CA did not have connector. Bike runs fine without, doesnt have 'check engine light' even though ECU was originally set to run Triumph's emission controlled map.
NSTriumph, do you have a bare green connector on your airbox?
"Dream like you'll live forever. Live like you'll die today."
James Dean
BBDGriptonia is offline   Reply With Quote
Old 04-08-2008   #5 (permalink)
Newbie
Yea its a grey connector. OK Emmissions control..thats what the connector was for.
As for the air temperature sensor on the bottom of the airbox,,,, there's nothing there. Should it be there?
Old 04-10-2008   #6 (permalink)
ok, what does it add to the motorcycle? will it run more efficiently? (will it give me more mpg?) or is it only for the emission, and how can i see if a sensor can be fitted (and how much does a sensor cost )
Old 04-14-2008   #7 (permalink)
Yes there should be a connector at the bottom of the air box, of to the mid left maybe?
Im not quite sure what the emissions control does, but the vacuum system connects to the throttle body system, then the exhaust manifold, and back to the airbox. Im not sure if the system itself gives more MPG, but the tune sure does. And no, you cannot equip a non-emission controled engine with the system without doing a head swap. The vacuum line units are mounted to the block on the engine head just above the exhaust manifold.
Anyone else have an actual answer for that last one?
James Dean
Problem with intake air temp sensor? trojan7horse Modifications & Workshop Talk 2 04-06-2008 10:54 PM
Daytona 600 & 650 NarrowBand O2 sensor Rik Triumph SuperSports 0 03-16-2006 07:20 PM
Air Temp Sensor Relocation drtim The Rocket Science Forum 10 11-01-2005 03:47 AM
Intake Air Temperature Sensor HardCharger757 Daytona Deliberations 2 08-01-2005 10:51 PM
