Progressive Insurance
TriumphPerformanceUSAAnnitori DistributingSportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!CycleGear.comBikeBanditAmericanMotorcyclistAssociationbritishcustoms
Trident-Exhausts.com
Old 03-01-2005   #1 (permalink)
After lowering my rear brake lever last week, I continued to lower the gear lever slightly. I have noticed more positive upshifts now, and less false neutrals. Alrighty then!
Live and let live
punisher is offline   Reply With Quote
Old 03-01-2005   #2 (permalink)
Punisher,
Was lowering the rear brake as much of a pain as it looks and do you have to play around with the light switch setting after?
I could do with it being a bit lower, but everytime I consider doing it, I just think 'Sod this, I'd rather be riding it' so never got around to it.
Paul
It's a fine line between a hobby and an obsession
Ghoti is offline   Reply With Quote
Old 03-01-2005   #3 (permalink)
its a little awkward, but not too grizzly. Just lube the nut under the rubber boot a bit to make it twirl just a little easier. Also, you can unclip, and remove the brass pin holding the peg to the brake cylinder to make it easier also.
Live and let live
Old 03-02-2005   #4 (permalink)
iI agree with both of you, Triumph got the angles slightly wrong.
Got mine just right. Then took it for 4k service and the 'stealer' "corrected" it !!!!!!!!!!!!!!!!
Bugggger!
Jon
Old 03-02-2005   #5 (permalink)
Rik
Favorite Bike: Speed Four
Rik's Avatar
I also lowered the gear lever which has massively improved the upshifts but took a while getting used to for the downshifts (with a few false neutrals on the way...)
I've been looking at rearsets to provide a better feel but they are far too £££ so now hoping the linked gearchange on the 650 will cost a reasonable amount and provide a better feel.
Rik is offline   Reply With Quote
Gear shift lever adjustment davidc Twins Technical Talk 6 07-07-2007 06:20 AM
training myself to be more gentlre with the gear shift lever tekmoe Speed Triple Forum 13 08-15-2006 10:49 PM
Gear shift lever replacement TexasTri Hinckley Classic Triples 3 05-02-2005 12:41 AM
Question about lowering the gear shift lever. Triumph SuperSports 3 07-19-2004 03:50 AM
gear shift lever rubber cover punisher Triumph SuperSports 0 06-12-2004 12:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
