It may be OK - the temp sensor may just be shorting a little (water can accumulate there, especially if you pressure wash). To check, you'd need to remove the left (as you sit on the bike) fairing. It's easy enough to find - a t the end of a load of wires with a push-release clip. Simply unclip the clip and look for water. If found, soak up, squirt with WD40 et voila. An easy and free fix, if it's the problem. Of course if it isn't the problem, it's time wasted, but worth a look?
Other cheap DIY fixes would be to check for air-locks in the radiator (not sure how to do that - someone will know!), obviously check coolant level and also check oil level. If either is low, the engine may run hotter than normal.
