Old 02-20-2008   #1 (permalink)
Favorite Bike: 04 Speed Four
Other Motorcycle: 71 BSA Lightening
Sprocket and Chain Question
Hey All.... how's it going? I have just ordered myself a Vortex 44-tooth rear sprocket. I am currently running stock 14/42 and wanted some more oomph off the line and also get the chain off the swingarm... is the stock chain long enough to fit the 44-tooth sprocket or do I need a longer chain??? A friend of mine told me I was good cause the increase of two teeth wasnt much of a change to need a longer chain, but I just like to run it by y'all cause you guys have done it already and have the first hand knowledge.... thanks all for the responses.....
tridrill is offline   Reply With Quote
Old 02-20-2008   #2 (permalink)
It would probably be tight, even with axle fully forward. How many miles are on the current chain?
B02S4 is offline   Reply With Quote
Old 02-20-2008   #3 (permalink)
3500 miles on current chain..... if stock chain isnt recommended then what would be the recommended chain length... i think stock is 120 links......
Old 02-20-2008   #4 (permalink)
Favorite Bike: 2004 Speed Four - green
Other Motorcycle: 68 Trophy (Saint) custom
I believe the stock chain is 106 links, the replacement chain comes with 120 links and you cut it down to size. I just came from picking my parts - 14t front, 45t rear and 120 link RK 525GXW chain. Not looking forward to cutting the linkless stock chain off though.
Moffat.
most commonly asked question from my friends - "have you got you bike back from the shop yet?" - "why don't you get a Ducati" - "bit wet out there hey"
Moffat is offline   Reply With Quote
Old 02-21-2008   #5 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
14/44 should work with the stock length chain.
Will
SponsorHouse profile
Old 02-21-2008   #6 (permalink)
Yak
Yak's Avatar
Stock length on 14/42 bikes is 106
Stock length on 15/45 bikes is 108
2005 Triumph Speed Four - Yellow
Yak is online now   Reply With Quote
chain/sprocket combo fergman Sprint Forum 7 02-01-2008 06:47 PM
new sprocket, new chain? metasac Twins Technical Talk 14 09-22-2007 01:14 AM
chain and sprocket question fbird Hinckley Classic Triples 8 03-30-2005 01:31 PM
Stock chain and sprocket? carbster09 Speed Triple Forum 2 01-20-2005 04:35 PM
after mkt chain and sprocket question Hinckley Classic Triples 9 12-02-2004 05:51 PM
