I have a wiring diagram but, can't read the colors on the wires. When I try and blow the diagram up to see it, I really can't see it. Does anyone have a very clear picture of the diagram for a 2001 Triumph tt600?
I'm having a problem with figuring out where the connection is for my R/R.
Its between two connections.
One place it can connect to is coming out of the engine.
And one is coming directly out of the wiring harness on the right side under the gas tank. The one coming off the wiring harness ( has 3 yellow wires, a 3 pin connector and is a black connector.
Hope someone can help!
Thank you!
Sent from my SM-G900V using Tapatalk
Thank you!
