AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBanditMotorcycle.com
Old 01-27-2005   #1 (permalink)
Has anyone removed the TT stickers from the fairings? I tried to take one off today and is was a disaster. I used a hairdryer to heat it up then I started peeling it off. The only problem is that the paint started peeling off with the sticker!!! Does anyone know how to take these things off without ruining my paint? I don't want to have to repaint my fairing after I take it off. Is there some sort of chemical that will loosen the sticker up so that it will wipe away?
Thanks
Old 01-27-2005   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
It sounds like you had too much heat. Be patient with it, work slowly, and use a hair dryier, not a heat gun. WD 40 removed the residue from my bike. If you use any kind of abrasive to get the residue off, it will dull your finish, but a good wax job polishes it right back up. The bike will look great without those goofy stickers! Mine has been stickerless for three years now.
Will
SponsorHouse profile
Will is online now   Reply With Quote
Old 01-28-2005   #3 (permalink)
I would not use heat on painted plastic. There are chemical sticker removers out there that should do the job.
Start on one edge.
use alot
plan a hour for each sticker.
as it starts to peel up add more of the sticker remover.
gently tug allowing the remover to seep under the edge of the sticker.
TAKE YOUR TIME!
Using heat is safer on metal painted surfaces i think.
MercyBeat is offline   Reply With Quote
Helmet Sticker Removal Xavi Helmets 8 05-29-2007 08:54 PM
Sticker removal TRIIICK The Rocket Science Forum 5 05-29-2007 04:06 PM
RS sticker removal! Help? Pharmaboy Sprint Forum 6 06-14-2004 05:16 AM
Tank Sticker Removal Beemie Hinckley Classic Triples 5 05-24-2004 01:57 PM
sticker removal teacherkeith Speed Triple Forum 7 05-10-2004 03:44 PM
