Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 11-11-2007   #1 (permalink)
stator wiring on TT600
Was just looking at the connectors that hook up the stator to the wiring harness and the one on the wiring harness side looks like it needs to be replaced. The plastic is breaking and the contacts are moving around way too easy. Can the connector alone be replaced or does the whole wiring harness need to be replaced to fix that.
Thanks
pyro_
pyro_ is offline   Reply With Quote
Old 11-11-2007   #2 (permalink)
Bomboderator
Favorite Bike: '00 Speed-TT
BombFactory's Avatar
Other Motorcycle: '02 CE Speedtona 955i
Unfortunately, I'm not seeing that there are harness plugs available separate from the main or sub harnesses. I would keep an eye on Ebay for a used harness. If there aren't any available, you might be able to use RTV silicone or fiberglass resin to repair the plug.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
Project Straight-Line: The TT600 Drag Bike
The philosophers have only interpreted the world, in various ways; the point, however, is to change it. - Karl Marx
BombFactory is offline   Reply With Quote
Old 11-12-2007   #3 (permalink)
Favorite Bike: 06 Speed Triple
redl1nerpm's Avatar
Other Motorcycle: Past: ZX9R, TT600
well you could always cut the connector off each side, and solder or crimp new connectors on. Just dont forget which wire goes to which
redl1nerpm is offline   Reply With Quote
Old 11-12-2007   #4 (permalink)
brought it into the dealer today and they are going to look at it but figure that they should be able to do something to fix it without a new harness being needed
Old 11-15-2007   #5 (permalink)
Favorite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
mine melted, had Cycleriders repair the connector(big mistake) then one month later it melted again. This time it was due to a bad connection in the new plug. cSo I used some nice sealed crimp-on connectors for each wire(I think 5). Haven't had a problem since.
Good luck.
kubbie is offline   Reply With Quote
Stator test correct? Will S4 stator work? redl1nerpm Triumph SuperSports 7 2 Days Ago 11:44 PM
Wiring diagram for a TT600? MickyC Triumph SuperSports 1 03-17-2007 12:06 PM
Wiring GPS to TT600 usnawolfe Triumph SuperSports 3 08-18-2006 07:26 AM
S4 stator on TT600 pyro_ Triumph SuperSports 8 05-30-2006 06:28 PM
TT600 alternator wiring seal problem MadMark Triumph SuperSports 1 11-17-2004 10:48 AM
