Progressive Insurance
Annitori DistributingTrident-Exhausts.comMotorcycle.com Classifieds!CycleGear.comTriumphPerformanceUSASpringfield ArmorySportbikeTrackGearBikeBanditMotorcycle.comAdvanstarMotorcycleShowsAmericanMotorcyclistAssociation
SportbikeTrackGear
Old 08-15-2007   #1 (permalink)
Coolant change help
Hi I was about to change the coolant.,... with the service manual etc etc... but can be sure of what bolts I need to undo...
This is a picture In red what I think are the coolant drain and the coolant breeder in the water pump...
I remove the radiator cap and coolant started flowing from the top... Didnt expect that but ive been told is normal...
What shall I do? I what I think is the drain coolant bold is behind a hose... shall I undo the hose?
I thought this was going to be easier Sad
Help!
DKScully is offline   Reply With Quote
Old 08-15-2007   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
What bike? I always just took off the hoses. It isn't the official way, I am sure, but it worked.
Will
SponsorHouse profile
Old 08-16-2007   #3 (permalink)
The bike is a Speed Four 05.
Which hoses do you take off?
Old 08-16-2007   #4 (permalink)
Will's Avatar
The lowest one I could find so everything drains out.
Will
Old 08-16-2007   #5 (permalink)
Favorite Bike: Daytona 600
pwrmedic1's Avatar
Coolant Change
If you will look around the footpeg on the left side there is a little nut I think it is about 11mm all you do is open it and the coolant runs out no problem.
I am remembering from my old TT600 and it is the same on my Daytona 600
Eric
pwrmedic1 is offline   Reply With Quote
re:coolant change ricster Sprint Forum 4 11-06-2007 10:29 PM
Coolant change help DKScully Triumph SuperSports 2 08-16-2007 11:46 AM
Brown coolant??? Coolant change?? Suncoast Sprint Forum 8 02-05-2007 12:51 PM
Coolant change Galesa Sprint Forum 4 09-15-2006 10:09 PM
Coolant change whistler Modifications & Workshop Talk 2 06-12-2005 11:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
