Originally Posted by jeedizzle
What is the best way to disconnect the fuel line from the gas tank without getting fuel all over.
Also when I took the left side fairing off. There were four hoses just hanging there is that normal?
All of your help would be greatly appreciated
Do it on an empty tank
anyway you get it off, it will spill a litte bit of gas, but if your quick it shouldn't make a mess.
As for the hoses, im assuming they are long and thin, running from what would appear to be just under the gas tank, correct? if so thats just your coolant and airbox run-off hoses, and the gas tanks spill tube. these should be held close to the engine body, just in front of the shifter i think.
