Old 11-25-2004   #1 (permalink)
Hi all,
Is there any way that the readout on a TT600 can easily be converted from MPH to KPH? (it's a UK spec 03 bike if that makes any difference)
I've misplaced my hand book at the mo. I'm only popping over to main land Europe for a bit so I don't want to bother with one of theose in line converters thingies, but apart from 62mph being 100kmh I can not remember other speeds and my poor old brain can't keep up.
Thanks in advance.
Paul
Paul
It's a fine line between a hobby and an obsession
Ghoti is offline   Reply With Quote
Old 11-25-2004   #2 (permalink)
easy fix, scroll through the readout until it displays the MPH and the time, then press and hold the select button for about 5 seconds and it will switch over to KPH. same process to switch back to MPH....
"when i let off the throttle it gets all squirrely, so, i just stay on the throttle.."
Joe275 is offline   Reply With Quote
Old 11-26-2004   #3 (permalink)
Thanks Joe,
Knew there must be an easy answer - I thought I had tried all combinations of buttons and readouts, but obviously not!
Paul
Paul
Old 11-26-2004   #4 (permalink)
no prob, glad to help. i don't think it tells how to do that in the owners manual, i found it out by accident..
Old 11-27-2004   #5 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
That is probably how we all find out about that hidden feature. You can have KPH/ degrees C, MPH/ degrees C and MPH/ degrees F. Each one is just another 5 second select button push away.
Will
SponsorHouse profile
Average kilometers/tank?? Nate13 Twins Technical Talk 15 12-15-2006 08:42 AM
955-no speedo readout, then bike cuts off stellasue Daytona Deliberations 4 09-09-2006 09:11 PM
05/06 Sprint "miles to empty" readout AlaskaSprint Sprint Forum 10 04-21-2006 10:52 PM
The 1st 1200 kilometers 1050Pome Speed Triple Forum 0 11-28-2005 04:44 AM
Coolant temp readout in degree F dsinned Daytona Deliberations 7 06-27-2004 12:50 AM
