Old 08-12-2007   #1 (permalink)
Favorite Bike: duh my TT
paint
So im playing around with some color combinations on a spare faring that i have..... and a question arises as i play. Shold i color/wet sand inbetween coats or inbetween colors... or just before clearcoat and then wet sand after clear coat
Matt
2001 Racing Yellow TT600
Be an Individual... Be a One-Off.
yakoo11 is offline   Reply With Quote
Old 08-12-2007   #2 (permalink)
also for prep should I hand sand everything or would a bead blaster be safe to use with the abs plastic?
does anyone know the percentages for paint/thinner/flex/cure??
I want to have all my bases covered before i show up to the spray booth....
Matt
Old 08-12-2007   #3 (permalink)
Favorite Bike: Speed Triple
Catenaccio's Avatar
Other Motorcycle: Speed Four
Extra Motorcycle: CBR1100XX
I'd ask an auto paint store for their opinions and follow the advice. Bead blasting would mar the surface of your bike. Sanding is the better choice. It's been 25 years since I worked at a body shop, so most of the little I can remember is bunk.
Catenaccio is offline   Reply With Quote
Old 08-12-2007   #4 (permalink)
but im lazy bead blasting would be so fast oh well thanks for the tips
Matt
Old 08-13-2007   #5 (permalink)
dynagroove's Avatar
are you an experienced painter or are you looking to get started? if you've got car experience, then it all translates to bikes - just remember that most parts are plastic or fiberglass. i finally got my act together and learned how to paint within the last year. while it has been a very rewarding experience, it has also been an expensive investment. your question about the wet sanding would depend on what type of paint you are using. with most modern paint systems, the actual painting and clearcoat stages are about 5% of the work - the remainder is in the prep. attention to detail is the key in the prep work, then spray the recommended coats of paint and clear (generally more clear than recommended actually) and that's it.
jeff h
dynagroove is offline   Reply With Quote
New Paint tealetm T3 Sport / Touring Forum 12 01-15-2008 08:08 AM
What to do with the paint uzidzit Twins Technical Talk 17 09-28-2007 09:21 AM
Paint or no paint... NewOldSkool Twins Technical Talk 3 07-02-2007 04:35 PM
PAINT Whitehurst Club Cafe 15 04-05-2007 09:16 AM
Paint gold paint on the Triumph logo on seat Fraederichs Twins Talk 11 09-05-2005 02:53 PM
