Old 08-07-2007   #1 (permalink)
TT600 popping and banging!
Hi,
I noticed that my TT (standard pipe and filter) 'pops' on the overrun, also, occasionally I get a big backfire when on the overrun that stalls the bike - it starts back up fine. Any ideas what this could be - is it running rich?
If so can adjustments be made by mechanics or is it main dealer only time?
Thanks for any info
Dave
hammer784 is offline   Reply With Quote
Old 08-07-2007   #2 (permalink)
Favorite Bike: 00 TT600 Red/Silver
Other Motorcycle: 04 Yamaha YZ450f
Extra Motorcycle: 00 Buell X-1 Lightning
What is "overrun"?
Popping/backfiring is mostly caused by air entering the exhaust and further fueling the combustion process. It's odd that way because too lean a mixture can cause backfires too. Backfires are essentially explosions in the pipe, which can and do bend valves.
The likely culprit is the exhaust donuts at the head, but if your can is loose, it can suck some air in there and pop a little. But that is pretty far back, so it'd have to be pretty loose.
The reason Santa is so jolly is because he knows where the naughty girls live.
x1wagner is offline   Reply With Quote
popping kc dave Trophy 23 01-30-2008 10:51 PM
Popping Modifications & Workshop Talk 19 03-16-2007 12:38 AM
Rear wheel banging around - Watch that rear axle nut! n578md Twins Technical Talk 6 09-17-2006 01:49 PM
popping itchin Speed Triple Forum 4 07-15-2006 09:17 AM
Banging and popping on new MAP HiVel Speed Triple Forum 17 02-25-2006 07:29 PM
