Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
ShopTriumph.com
Old 08-01-2007   #1 (permalink)
Favorite Bike: 00 S3
fuseable links
touched the blinker/flasher wires together and blew the relay, and the temp gauge light went out as well as the blinkers. replaced the relay, fuses, bulbs, tested switch/button, voltage to relay plug.. Still nothing
Am i missing something?
cap-10ken is offline   Reply With Quote
Old 08-02-2007   #2 (permalink)
Bomboderator
Favorite Bike: '00 Speed-TT
BombFactory's Avatar
Other Motorcycle: '02 CE Speedtona 955i
That is an interesting problem. I just took a look at the wiring schematic and I cannot locate any fuseable links within the area you are concerned with. This makes sense, as I wouldn't think a fuseable link in that wiring would be needed. I might be mistaken and there could be one somewhere. If I were in your position, I would track the wires back until I reached the point where the current stops. Sorry I can't be of more help.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
Project Straight-Line: The TT600 Drag Bike
The philosophers have only interpreted the world, in various ways; the point, however, is to change it. - Karl Marx
BombFactory is offline   Reply With Quote
Old 08-03-2007   #3 (permalink)
yo thanks a lot for the sensible response it doesn't seem to make any sense to anyone else either. How could everything else work tail light, pass button, high beam, low beam, horn, tack light, RPM light but no blinkers or temp light? Tested switch with a TT and Sprint(both 00), replaced all lamps, fuses, and relay still nothing
Again thanks
useful old links londonBonnie Twins Technical Talk 10 11-11-2007 09:25 AM
fuseable links cap-10ken Modifications & Workshop Talk 1 09-05-2007 04:48 AM
fuseable links cap-10ken Sprint Forum 2 08-02-2007 05:21 AM
fuseable links cap-10ken Speed Triple Forum 0 08-01-2007 09:32 PM
How many links... Sparti Speed Triple Forum 6 09-09-2006 09:33 AM
