AdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
BikeBandit
Old 07-27-2007   #1 (permalink)
overflow tube
I have an 01 tt600 and when I stop after a semi hard ride oil comes out of the overflow tube. I have been told it is some type of pressure valve but I was wondering if anyone knew exactly what it was?
bkjones is offline   Reply With Quote
Old 07-27-2007   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
Oil or antifreeze? You should never get oil out of the drain hose. If you are, then the centrifugal breather valve on the right side of the engine may be screwed up and pumping oil into your airbox. That isn't a good situation for a lot of reasons.
Will
SponsorHouse profile
Old 07-29-2007   #3 (permalink)
it is oil out of the drain hose. its when i stop riding though not during and it only lasts for a couple seconds.
Old 07-29-2007   #4 (permalink)
Will's Avatar
Take a look inside the airbox. It will have oil in it, not a good situation. You need to replace the centrifugal breather valve on the right side of the engine and clean everything out.
Has the bike been dropped on its right side?
Will
Old 07-29-2007   #5 (permalink)
I think it has been dropped but I thought it was the left side. I bought it used. How big of a problem is this?
Old 07-29-2007   #6 (permalink)
Will's Avatar
It makes a big mess in time if not fixed. You won't kill your bike right away, but it will make it run poorly and eventually shorten the engine's life.
Will
Old 07-30-2007   #7 (permalink)
Favorite Bike: 02 Sprint RS
rs_tt's Avatar
Other Motorcycle: 1983 Suzuki GS250FW
+1 to what Will said , I just did this repair to my wife`s TT600, the new centerfugal is redeisign -slightly longer and a tapered end where it goes in to the seal. you`ll need the breather ,seal,and the breather cover gasket. I also sealed(silicon) up the seam down the middle of the air box as oil would drip out of there and run down the engine and make it look like the stator cover was leaking oil.
It`s a real easy fix.
Will it was nice meeting you at the cycle barn
pieracer
rs_tt is offline   Reply With Quote
Old 07-30-2007   #8 (permalink)
Do you happen to have the parts numbers to those items?
Old 07-30-2007   #9 (permalink)
Will's Avatar
It sure was! Are you one of the army of Canadians who are headed down to the track the first weekend of September? Last I heard, there were something like 17 riders coming down.
Will
Old 07-30-2007   #10 (permalink)
rs_tt's Avatar
bkjones
i`ve probably missed somthing but maybe some one else here can point that out, sorry no part numbers
---Take off the side fairings (you can get away with only brake lever side)&seat& disconnect battery
---Unbolt the tank lift gently at the rear and note where all vacuum+ drain and fuel lines go, the fuel lines have colored fittings (red to red..white to white)
to remove the fuel lines push the metal tabs in and gently pull down,un hook the vac+ drain lines lines, and fuel pump wires....take tank off and set carefully aside.Extra hands help with disconnecting the fuel lines.
If you remove the air box ,, note where all the hoses go. You can clean out the air box by removing the air filter and wiping it out gently with a rag.becareful not to damage any sensors in there.
The breather cover is on the brake of the engine with a large black breather hose coming out of it remove this cover(don`t forget to clean your gasket surfaces),on the inside of this cover you see a small inner wheel bearing type seal,, replace this seal.
The centrifugal is that thing with the plastic wheel that goes in to that seal, its held on by an Allen head bolt into the crank unbolt it and you may have to gently pry it off, fit the new centrifugal(align the keyway) and torque to 30NM(easier with bike in gear) , replace gasket, put some clean oil on the breather seal and the centrifugal shaft replace cover torque bolts to 9NM.
put bike back together.
A shop should be able to this in 1 hour if you choose to go that way.
hope this helps
pieracer
AI removes LEFT tube but what is the RIGHT tube for? ocguyocguy Twins Technical Talk 2 01-26-2007 11:10 PM
Oil overflow? hootieST Sprint Forum 9 08-29-2006 05:58 PM
petcock / overflow (Help?) Tre900 Hinckley Classic Triples 3 08-04-2006 12:19 PM
Fuel overflow? CYLax Modifications & Workshop Talk 9 07-19-2006 09:25 AM
what is this? fuel overflow? whoa Tiger Workshop 10 12-29-2004 07:43 AM
