overflow tube - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 28 (permalink) Old 07-30-2007, 08:44 PM
Main Motorcycle: 2008 1050 ST
rs_tt's Avatar
Other Motorcycle: 02 Sprint RS..sold
Originally Posted by Will View Post
It sure was! Are you one of the army of Canadians who are headed down to the track the first weekend of September? Last I heard, there were something like 17 riders coming down.
No, not as far as I know,,,the wife may have other plans tho
rs_tt is offline
post #12 of 28 (permalink) Old 07-31-2007, 02:38 PM Thread Starter
I have been looking here on bike bandit. I think I need parts 16 and 18 in the schematic I will provide a picture at the bottom. Let me know, thanks.
bkjones is offline
post #13 of 28 (permalink) Old 07-31-2007, 05:13 PM
rs_tt's Avatar
yes,,I replaced the centerfugal too(under the advice of the triumph tec the new ones are longer) , I think its under the crankshaft heading at bike bandit.but you may be able to get away with replacing just those 2 items
rs_tt is offline
post #14 of 28 (permalink) Old 07-31-2007, 06:25 PM Thread Starter
Part number 13 in the crankshaft section? Do you think it would stop the leak if I only replaced those two items?
bkjones is offline
post #15 of 28 (permalink) Old 07-31-2007, 11:43 PM
rs_tt's Avatar
yes,the tech at the shop suggested we change it too,the new one I got is longer and has a tapered end that makes it less likley to damage the seal when you reassemble it . make note of which way the seal goes in when you put i back together. heres a link to another way of doing it
http://www.bikersoracle.com/tt/forum...read.php?t=841
rs_tt is offline
post #16 of 28 (permalink) Old 08-02-2007, 05:07 PM
I remove the breather hose from the air box entierly. plug the hole in the air box and re rout the hose to a catch can to keep from blowing oil into your airbox if you do drop it. I took a longer hose and re routed the breether over and behind my rear wheel, but this is my track bike.
Agkistrodon "aka" billy badass
check out my sponsorhouse profile.
http://www.loopd.com/Members/texaspro/Home.aspx
Agkistrodon is offline
post #17 of 28 (permalink) Old 05-24-2011, 06:01 PM
Newbie
Main Motorcycle: speed 4
Does anyone remember what the "other" way of doing it was from this link i've quoted? The forum has been erased and i'm trying to find another way of doing it.
mrjason is offline
post #18 of 28 (permalink) Old 12-04-2012, 02:47 PM
Main Motorcycle: TT600
bikerboy1's Avatar
Extra Motorcycle: pushbike
[QUOTE=Will;779780]Oil or antifreeze? You should never get oil out of the drain hose. If you are, then the centrifugal breather valve on the right side of the engine may be screwed up and pumping oil into your airbox. That isn't a good situation for a lot of reasons.[/QUOTI
I have this problem but no oil in my airbox?!
only happens in hot weather though
bikerboy1 is offline
post #19 of 28 (permalink) Old 12-06-2012, 02:33 PM
Main Motorcycle: Very fast 675
Official Leathers Tester
Will's Avatar
Other Motorcycle: DRZ 400 Bad Idea
Oil or anti-freeze?
Will
Will is offline
post #20 of 28 (permalink) Old 12-11-2012, 02:10 PM
Main Motorcycle: 2003 Speed Four
Can someone link a new picture to the Breather in question. It seems as though my bike is sucking oil into the intake as I'll often get a large plume of smoke when I start the bike or come to a stop light sometimes.
Thanks fellas
ibark is offline
AI removes LEFT tube but what is the RIGHT tube for? ocguyocguy Air Cooled Twins Technical Talk 2 01-26-2007 11:10 PM
Oil overflow? hootieST Sprint Forum 9 08-29-2006 05:58 PM
petcock / overflow (Help?) Tre900 Hinckley Classic Triples 3 08-04-2006 12:19 PM
Fuel overflow? CYLax Maintenance & Workshop Talk 9 07-19-2006 09:25 AM
what is this? fuel overflow? whoa Tiger Workshop (archive) 10 12-29-2004 07:43 AM
