balanced wheels vs headstock bearing vs bad california roads - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.comNew Bonneville
Old 07-20-2007, 09:23 PM   #1 (permalink)
Favourite Bike: duh my TT
Other Motorcycle: Sv650
Extra Motorcycle: f4i
"If it's the front wheel, you'll experience shudder in your mirrors and handlebars, mostly felt anywhere above 60mph. You steering head may be slightly damaged, and your tire will wear unevenly...." (airrider3)
well,
anything high speed above 60 is nice and smooth and I dont notice any bounce or anything until I use the engine to decel could I just need to inspect and tighten my headstock bearing???? how easy is this to do and what tools will I need im assuming a front stand... or could it just be crappy southern california roads
and if thats the case how could I adjust my suspension to minimize this bounce.. right now im at stock settings
Matt
AFM #940
2001 Racing Yellow TT600
yakoo11 is offline   Reply With Quote
Old 07-20-2007, 10:29 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
I gotta say, you are confusing me completely. If you get some shake on deceleration, including when you are braking, then check the headstock bearings. If you get a shudder under braking, then check the brake pads or the brake disks. If you get a shudder at certain speeds, then check wheel balance or roundness.
Will
SponsorHouse profile
Old 07-20-2007, 10:47 PM   #3 (permalink)
I slide under the front end of the bike and look up and there is a bit of grease surrounding the lower end of the bottom triple tree(where the triple tree connects to the frame)... I assume this is part of the headstock bearing and probably should not be leaking any oil/grease/lube..... maybe i have a damaged headstock bearing...
I think i will just take it to the stealer.... thanks for all the help though.. maybe the BMW shop down the block will work on it?? the Triumph dealer is farther away.
in the service manual they have a 3 yr/ 18000 mile service but in the mom there is no mention just 16000 then i assume a 20000.
does this 18000 acually exist and anyone know how much it will run??
Matt
AFM #940
2002 Sprint RS Headstock bearing MikeP Speed Triple Forum 0 05-20-2007 11:12 AM
Headstock bearing jnicosia Speed Triple Forum 1 05-01-2007 06:33 PM
Cool roads in N. California dcorbell Speed Triple Forum 10 01-12-2006 02:09 PM
Headstock Bearing Adjustment - Thunderbird SWare Maintenance & Workshop Talk 10 12-26-2005 10:21 PM
Headstock Bearing Adjustment cyrmc Sprint Forum 0 03-30-2004 11:35 PM
