Thats why you use a mixture of coolant and water. The coolant (Ethylene Glycol) raises the boiling point of the water so it doesn't boil over. The pressure in the system counter acts boiling as well.
These bike run hot, as Fury mentioned, the fans dont even come on till 222F. I've had mine up to 238F in traffic and although thats pretty ***** hot, it not a problem. The high temp light comes on at 248 I believe.
2005 Triumph Speed Four - Yellow
