electronics failure??? help - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-07-2007, 02:11 PM   #1 (permalink)
joshuacoleman
the strangest thing. i am riding my S4 then all of a sudden the speedometer flashes to 188 and the rest of the meters stop reading anything. and every time i rev the numbers all disappear. this somehow causes the battery to loose all of its juice and then i can't start the bike if i turn it off. as u can imagine this is hyper annoying especially being in southern California. any ideas at all before i take it in and spend a buttload of money trying to figure it out.
-its a new battery too
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/IHbNNOjaUFI"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/IHbNNOjaUFI" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Old 07-07-2007, 03:32 PM   #2 (permalink)
tineg
i too am having that very problem, new battery and all. in fact that is why i'm on the this right now instead of out on the bike. any help would be appreciated!!!
Old 07-07-2007, 03:36 PM   #3 (permalink)
It looks like your are going to have to spend that buttload of money. The bike might just need a reflash of the ecu, or who knows. My bike is also at the shop with electrical problems.
jared26jlvigil2 is offline   Reply With Quote
Old 07-07-2007, 03:46 PM   #4 (permalink)
Yak
Yak's Avatar
I though the days of "Prince of Darkness" were over.
2005 Triumph Speed Four - Yellow
Yak is offline   Reply With Quote
Old 07-07-2007, 04:38 PM   #5 (permalink)
FuryFour's Avatar
it does that when the battery is low/dying
if a new battery fixes it for a short while, then you have stator/regulator problems.
if not, you have wiring/ECU problems.
| 2006 Triumph Speed Four - SOLD |
| 2001 Triumph TT600 - SOLD |
| 2008 Triumph Daytona 675 - NEW |
| 1979 Honda CX500 - Old and Ugly |
| 2008 Dodge Ram 1500 Big Horn - Support Vehicle |
FuryFour is offline   Reply With Quote
Old 07-07-2007, 04:46 PM   #6 (permalink)
Favourite Bike: '06 Triumph Speed 4
The first thing to do is have the battery tested. You can do this at most auto parts stores for free. If the battery is shot, buy a new one. That behavior could be a dead battery (it'll pull all the current the alternator produces so not enough gets to the gauges). It could be a bad alternator, or, as Fury said, it could be wiring/ecu/bad things.
It's much more likely that it's a charging system problem than a wiring/ecu issue, fwiw.
[ This message was edited by: rustbucket on 2007-07-07 14:49 ]
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Old 07-08-2007, 01:40 PM   #7 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Stators eventually get tired and have to be replaced. If the stator is tired, you don't get enough juice to keep the battery charged, and as the battery drains, the problem will come back.
Will
SponsorHouse profile
Flaming Electronics! 2Scared2Wheelie Speed Triple Forum 3 04-10-2007 02:21 AM
Tachometer failure KevinH Sprint Forum 3 01-17-2007 12:18 AM
Rain vs. electronics deaddeaddead Speed Triple Forum 4 12-16-2006 11:54 AM
Electronics cluster problem on '06 S3... kdriven Speed Triple Forum 4 05-05-2006 05:55 PM
cycle electronics Maintenance & Workshop Talk 4 07-10-2004 02:53 AM
