It is a little confusing. The maps are Triumph maps. I don't know where Wayne got them, but they are the stock maps. He doesn't charge you to download them.
You buy a cable for a certain amount of money. I don't remember what the exact number is. It plugs into the USB port (or parallel port for an older cable) on the back of your computer and into the connector on any bike it fits. The same cable can be used on dozens of bikes if you have dozens of bikes to plug it into.
You also buy an unlock code for each specific ECU you want to communicate with. I don't remember whether the diagnostic functions work without an unlock code or not. I know for a fact the mapping functions don't work without an unlock code. Once you have the code, you put it into the right place on the program and it allows you to load maps, modify maps, etc however you want in one specific ECU. If the ECU fails, you need to get another unlock code for the next ECU. If you get another bike with a different ECU, you need another unlock code, but no new cable. If you move the same ECU from one bike to another, the unlock code will still work on the same ECU.
The software itself is a download Wayne doesn't charge for.
I hope that clarifies things a bit. I agree it isn't at all easy to untangle until you have been messing with it for a while. Unlike a Power Commander, you can't just move from one identical bike to another, but also unlike a Power Commander, you can go from a TT600 to a Sprint ST to a Daytona 675 to an S3 without needing all new hardware. You would just buy unlock codes for each of the new ECUs.
Will
SponsorHouse profile
