Damb muffler can - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-03-2007, 03:39 PM   #1 (permalink)
GRRR!
I tried to do some preventative maintenance on my bike and now need to buy a new muffler can. The 3 bolts holding the can on kept working their way out, so I tried to pull them out and was going to put some lock tight on them. Well one came off fine, put the lock tight on it and put it back in, but the other two got half way out and then just started spinning. The I tried to take out the one I had done previously, and that did the same.
I wound up taking a dremmel and cutting the bults. So now i have a beautiful carbon fiber can that has no threads on the end. My guess is that there was some nuts spot welded to the back side, and the welds broke loose.
I jumped on ebay and bough a beat up stock can as a buy it now, and a few days later won a used yoshimura rs-3.
Thought I would share the story.
-wiley
wileytt is offline   Reply With Quote
Old 07-03-2007, 04:54 PM   #2 (permalink)
Favourite Bike: D650
redl1nerpm's Avatar
Other Motorcycle: Past: ZX9R, TT600, S3
you can probably buy a tap and die set and either clean up the threads on your cf or create newer larger ones. That or bring it to a machine shop and they can do it.
[ This message was edited by: redl1nerpm on 2007-07-03 14:54 ]
redl1nerpm is offline   Reply With Quote
Old 07-03-2007, 05:33 PM   #3 (permalink)
Favourite Bike: '06 Triumph Speed 4
Bummer. Was it the Triumph carbon can that you had the problems with?
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Old 07-05-2007, 12:19 PM   #4 (permalink)
It was the Triumph Carbon can that i ran into trouble with. I am going to see if i can't retap the screw holes. and then either put the rs-3 can back on ebay or the fixed triumph one.
-bj
Old 07-05-2007, 08:46 PM   #5 (permalink)
Favourite Bike: 07 Blue S3
BBDGriptonia's Avatar
Other Motorcycle: 97 Bandit - Sea Bass
let us know first if you put either on :-D
"Dream like you'll live forever. Live like you'll die today."
James Dean
BBDGriptonia is offline   Reply With Quote
Two Tone Muffler chedd Twins Technical Talk 12 12-31-2007 05:11 AM
Muffler Meat drharveys Biker Hang-Out 21 12-18-2007 02:57 PM
Gas out of the muffler?! Tre900 Hinckley Classic Triples 12 05-27-2007 11:16 PM
2002 CF Muffler motogeezer Sprint Forum 3 10-06-2006 06:35 PM
muffler disaster JonCG Twins Talk 5 08-30-2005 07:28 PM
