Alright, the Triumph shop manual doesn't say anything about how to test the charging system, so I'll try from memory.
Voltage coming directly from the stator, unplugged the main harness, should be somewhere around 30 volts AC. Yes I said AC.
The regulator is also a rectifier which converts AC into DC, but it also reduces the voltage down to 13.5-14.5 volts.
With everything plugged in and charged up, you should see minimum of 13.5 volts and a max. of 14.5 volts. Regardless of engine rpm.
When you rev the engine you should be able to see the lights get brighter.
Also if regulator is working right you will burn your hand if you touch it (it makes a lot of heat changing from AC to DC).
This is info from older bikes, but the parts do the same thing, only better!
kubbie
kubbie
"I'll call you if you need me"
