?'s about 00 tt600 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-02-2007, 07:25 PM   #1 (permalink)
Hi everyone,
I'm new to street riding and bought a 00 TT600. So far I love the bike, but I want to be able to keep enjoying it. I would like to know what maint. I should be doing to it for the bike to last and run properly. It has 9,300 miles on it.
mcoop is offline   Reply With Quote
Old 07-02-2007, 07:42 PM   #2 (permalink)
Favourite Bike: D650
redl1nerpm's Avatar
Other Motorcycle: Past: ZX9R, TT600, S3
iirc the valve adjustment should have been done at 8k so if you dont have record of that, you may want to have it done. The chain on these bikes gets worn quickly because of the pad (forget the name) but there are some posts about taking care of that. Even if you don't do it make sure to lube that chain a lot.
Of course do the typical stuff like routine oil changes with the recommended oil, coolant flush at recommended intervals (these bikes run at high temps), and again lube your chain every few hundred miles at least..
redl1nerpm is offline   Reply With Quote
Old 07-02-2007, 07:43 PM   #3 (permalink)
Do you know the person you bought it from and did you get service records?
If not, take it in for an oil change (every 3000, according to my dealer). They did a minor service and gave things a once-over when I brought it in. They ended up installing new rear brake pads and tightening up some loose bolts. Do that now since you're at 9k. Mine ended up being about $300.
gamo is offline   Reply With Quote
Old 07-02-2007, 11:14 PM   #4 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Change the oil yourself- it is easy to do and a whole lot cheaper than taking it somewhere. Chances are the valves are in spec, but getting them checked is worth the price. Also, make sure the throttle bodies are synchronized and the CO is set properly. If you have low end problems, get the 2002 on map loaded. The dealer will look at you like you are nuts, but it is the best map for pretty much all TT600s. If you have an aftermarket pipe, send a PM to Craig (clutchNthrottle) and get his famous map. It works well as long as you run your bike hard periodically to blow out the carbon.
Will
SponsorHouse profile
Old 07-03-2007, 06:44 PM   #5 (permalink)
Thanks everyone for the input, I plan on taking it in to get everthing looked at when it goes in for inspection this month.
TT600 - should I get one? MickyC Triumph SuperSports 20 12-14-2006 05:57 PM
TT600 vs. S4 BBDGriptonia Triumph SuperSports 2 12-07-2006 08:29 PM
TT600 kins12 Maintenance & Workshop Talk 5 06-24-2006 05:29 PM
TT600 LCB Triumph SuperSports 10 06-04-2005 03:41 AM
