BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 06-05-2007   #1 (permalink)
I took my bike out for a test run up and down the street. Somehow my cloth keychain lanyard in my pocket ended up in rear wheel bearing....
I've been nothing but bad news for this bike. How can I get what's left of the lanyard out? I have a feeling I'm going to have to take this one to the shop.
gamo is offline   Reply With Quote
Old 06-08-2007   #2 (permalink)
Bomboderator
Favorite Bike: '00 Speed-TT
BombFactory's Avatar
Other Motorcycle: '02 CE Speedtona 955i
I noticed that your post has gone unanswered for some time--sorry about that. Incase you have yet to fix the problem, I believe that you are probably getting the wheel bearings confused with something else. The wheel bearings are sealed roller ball bearings which make it very hard to get anything stuck in them--especially a cloth strap. I'm thinking that the cloth might have been sucked into/under the grease seal, but I obviously don't have your bike in front of me so I am only speculating. In any case, you will have to drop the wheel from the swingarm if you are unable to get all the material out as it is. Once you remove the axle, let the wheel drop and you should be able to reach in and get all the material out. If you had to, you could carefully remove the grease seal and then you'd have full access to the bearing.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
Project Straight-Line: The TT600 Drag Bike
The philosophers have only interpreted the world, in various ways; the point, however, is to change it. - Karl Marx
BombFactory is offline   Reply With Quote
Old 06-08-2007   #3 (permalink)
How would the lanyard get stuck in the seal? Please provide a picture...
-Jon
Jon916996748 is offline   Reply With Quote
Old 06-08-2007   #4 (permalink)
I got it off. I just had to pull real hard and roll the bike backwards. Repeat Repeat and it came out.
The lanyard was in my pocket and it got caught in the chain and tore off. It wound itself on the axle... or whatever. The good news is I didn't have to take it to a shop.
A friend of mine had a similar issue, he took off on his Ducati with the tie-down chain still attached. It got tangled in his wheel as well. He's the one who suggested pulling/rolling back.
Old 06-09-2007   #5 (permalink)
Ahh, that is good news. This is the very reason I wear my boots, no laces .
-Jon
Triumph key/alarm lanyard? wingedwraith Biker Hang-Out 4 08-14-2007 10:19 AM
Bike Caught Fire npicklo Speed Triple Forum 65 02-20-2007 06:39 PM
Caught up with Bucket shiver Speed Triple Forum 2 10-19-2006 01:20 AM
Caught 'em! Frankie Club Cafe 15 12-15-2005 08:11 PM
caught up in history Spota Twins Talk 7 07-21-2005 06:20 PM
