Old 06-04-2007   #1 (permalink)
Hey, folks,
I just changed the coolant in my S4. I know that it's supposed to take 2.64 US quarts/2.5 liters. It seemed like it only took just over 2 quarts.
I followed the instructions in the manual. Pulled the coolant drain plug, loosened the bleeder screw and pulled the hose by the water pump (actually had to pull the hose by the bleed screw, too). I put everything back together, filled the radiator, opened and closed the bleeder screw and then ran the bike for a bit so it would suck down some coolant (I burped the hoses while it was running). Then I filled it again. I also filled the overflow tank.
Anyway, it didn't seem to take as much coolant as it should have.
(I will note that the old coolant that I drained all fit in a 2 liter Coke bottle, which also seemed strange).
Thoughts?
Thanks in advance.
p.s.-I hadn't had any overheating problems with the old coolant. It was just time to change it out.
[ This message was edited by: txsport06 on 2007-06-04 20:18 ]
txsport06 is offline   Reply With Quote
Old 06-05-2007   #2 (permalink)
Other Motorcycle: Duc999/S3/D650
You may have an air bubble in the system. Clamp off the hose from the overflow tank, then pop the radiator cap and run the engine briefly and see if you can add more water.
Billybob
Billybob is offline   Reply With Quote
Old 06-05-2007   #3 (permalink)
There is still coolant in the engine, its very very hard to drain every last bit, I wouldn't worry about it.
rockhopper1998 is offline   Reply With Quote
Old 06-08-2007   #4 (permalink)
Thanks, folks. Well, I finally got the bike out for a ride. Temps were at the usual levels for an 80 degree day. Coolant level looked fine when I got back (I guess that the bike just didn't want to give up that last .5 liter when I drained it).
When I changed out the coolant, I added some Water Wetter for good measure. It didn't lower my high temps (it's still in the 220's F at lights), but the bike seemed to cool off a bit faster once I got moving.
[ This message was edited by: txsport06 on 2007-06-07 23:15 ]
adjusting throttle play - how the hell to reach the adjusters jpeake Speed Triple Forum 10 05-09-2007 08:21 PM
Help with skyking slider install? Can't reach rear bolt mperetz Speed Triple Forum 17 04-19-2007 11:42 PM
My carbs won't reach the airbox! JEB Twins Talk 3 04-13-2007 04:01 PM
I can reach the ground (now) Trumpy1050 Speed Triple Forum 9 12-05-2006 11:38 PM
Flushing 01 coolant, no manual? coolant bubbles after use! speedtripleride Speed Triple Forum 1 05-21-2006 11:53 AM
