Motorcycle.comTrident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
Old 06-04-2007   #1 (permalink)
Hi there everyone, I have a 2002 TT and the rear footpegs have some play in them when they are folded up and when they are locked down. In certain rpm ranges they vibrate so much and its very annoying even with a full face helmet on I can hear it. Most of the time, what needs to be replaced and does anyone know of a cheap fix (besides removing them) Thank you! -Spin :???:
spin is offline   Reply With Quote
Old 06-05-2007   #2 (permalink)
The square spacer with the locating hole for the ball bearing wears , allowing too much movement letting the footpeg vibrate against the bracket.
Piece of cake to use slightly thicker steel and cut a new spacer to suit...not forgetting the hole for the ball bearing.
freddytin is offline   Reply With Quote
Old 06-06-2007   #3 (permalink)
Thanks, Has anyone ever done this?
WTB rear footpegs for 2002 955i Tiger nomad747 Tiger Chat 2 09-06-2007 02:27 AM
Noisy rear brake caliper mounting bracket spm0912 Speed Triple Forum 0 07-17-2007 02:00 PM
tt600 rear hugger jhintw Triumph SuperSports 5 09-18-2006 08:13 AM
99 TBS Rear Footpegs cowboyfitter Hinckley Classic Triples 5 01-23-2006 09:28 AM
Rear footpegs wanted Brit-in-Athens Daytona Deliberations 0 08-17-2005 02:19 AM
