AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.com
Old 05-25-2007   #1 (permalink)
The local racing organization requires I remove the kickstand from my bike. The problem is when I disconect the kickstand switch the bike will not start. I assume I can take part of the wire and the connecter and jumper it where it enters the wireing harness to fool the computer. But Im not sure which wires are wich and even if I knew that I wouldnt know the right combination. Anyone been here before?
Agkistrodon is offline   Reply With Quote
Old 05-25-2007   #2 (permalink)
dynagroove's Avatar
not on the S4 or TT600, but i've done this on an SV. without looking at the specific wiring, you will need to remove your kickstand switch from the harness and use a multimeter to determine which wires complete the circuit with the switch closed. short the connectors on the harness for those wires and you are good to go. hth
jeff h
dynagroove is offline   Reply With Quote
Old 05-31-2007   #3 (permalink)
Remove and unplug the kickstand switch. Take a paper clip or piece of safetywire and stick an end in each slot of the plug. Add a zip tie for security and a piece of tape, heat shrik or silicone to insulate the exposed portion.
If you're looking for any track/race stuff for the TT, I've got a bunch of parts and spares I've been meaning to list, drop me an email if you're interested.
The British Bulldog: '06 Speed Triple - 11.34@122.84
Black Sunshine II: '06 TrailBlazer SS - 13.17@105.23
http://i69.photobucket.com/albums/i4...609-sigsiz.jpg
clutchNthrottle is offline   Reply With Quote
kickstand modre Twins Technical Talk 15 12-02-2007 03:47 AM
trackbike paintjob Agkistrodon Triumph SuperSports 14 01-28-2007 03:59 PM
kickstand robbierob The Rocket Science Forum 25 03-03-2006 08:03 PM
tt600 kickstand bolt fell off chadoll Triumph SuperSports 8 12-19-2005 12:45 PM
new Kickstand? GrayRocketIII The Rocket Science Forum 0 07-21-2005 09:20 AM
