You may also want to check to see if the fuel connectors on the tank have been changed over to the metal ones, and if not you should change them while you have the tank off.
Indeed. This was a recall, so if you find the plastic connectors you may want to get your dealer to change them over (assuming it's still free).
Getting the tank off is pretty simple - three bolts come off, lift up the tank (I found help handy for that, others have more faith in their own ability), disconnect the hoses (just push and release) and the power clip. The clip was a***** on mine.
Airbox lifts off if I remember correctly to reveal the injectors, which you may want to cover. There are some connectors and hoses attached somewhere under there too, but I can't remember where. I can remember one fell off, so keep an eye on it.
And underneath are the HT leads. If you're not going to take the cam cover off, (which you probably can't without removing the radiator) make sure you have a long enough socket to reach the plugs.
