Old 10-07-2004   #1 (permalink)
after an accidant:
the thread on the motor base, where the water pump is screwed, was broken apart into the crash, the motor base doesn't seems to be broken other then that.
I have full coverage on my bike including replacement in case of total wreck and new parts replacement in case of partial wreck.
The problem is that the insurance company wants to have the motor base solder and the threads redo instead of replacing the motor base.
My question is, will it affect the metal in anyway if they weld on it, I think it's aluminium right. Will it affect my waranty and the reselling value of the bike.
green is offline   Reply With Quote
Old 10-07-2004   #2 (permalink)
after an accidant:
Old 10-13-2004   #3 (permalink)
Favorite Bike: My Speed Triple 'SS'
Other Motorcycle: My '03 Daytona 955i
Having the piece welded will not effect the integrity of the part. In fact it will probably be the strongest part of the case. You should just make sure that (1) the welder knows what he is doing, and (2) the case is finished off so that there is no sign of the repair.
Pablo is offline   Reply With Quote
Welding for dummies TCL Club Cafe 13 06-26-2007 04:27 AM
Base decal on a Bonnie pbpeel Twins Talk 6 04-26-2006 11:21 PM
Base Decal Tarr Twins Talk 19 04-15-2006 12:55 AM
Base nut wrench wudstoc Classic, Vintage & Veteran 6 02-22-2005 01:46 PM
Plastic welding of fairing parts BruceG Modifications & Workshop Talk 5 05-12-2004 04:19 PM
