Old 04-02-2007   #1 (permalink)
Have taken the plunge after months of consideration and ordered my LSL risers and superbike bars from Jack Lilley today!
Before it arrives, I have a couple of questions for any of those out there who have already converted their S4s.
Having done a bit of research on this forum, it seems I should be able to use the existing throttle / clutch cable and front brake line with a bit of sensible routing.
The first question is, how do I remove the fuel tank enough to route the cables as necessary?
The second is do you have any advice on re-mounting the master brake cylinder?
Any other advice greatly accepted!
Cant wait for it to arrive now!
Ninjaboy is offline   Reply With Quote
Old 04-03-2007   #2 (permalink)
I have used my existing throttle and clutch cables, just moved them around a bit and didn't need to remove the tank. The kit comes with a new braided, longer front brake hose (well mine did anyway). The kit also came with a new bracket for the master cylinder, however to make mine fit I had to use a plastic tube clamp on the bars as well.
kiwifour is offline   Reply With Quote
Old 04-03-2007   #3 (permalink)
kiwifour,
do you have any photos of the conversion??
ender is offline   Reply With Quote
Old 04-03-2007   #4 (permalink)
I'll see what I can do this long weekend, out of town until then.
Old 04-03-2007   #5 (permalink)
Coincidently enough, I just ordered a kit too, though I'm getting it from Team Triumph in Wisconsin. They said it should be here by the end of next week. Looks like I'll have a nice little project for the weekend.
kodos is offline   Reply With Quote
Old 04-03-2007   #6 (permalink)
Whats the benefits of the LSL conversion compared to stock bars?
Reppyboyo is online now   Reply With Quote
Old 04-03-2007   #7 (permalink)
Some see a benefit in a more upright riding position, and more leverage due to a wider grip, both are pluses for around the city. It also looks good, however I still can't talk my self out of clipons, since I have bars on my ktm.
2003 Speed Four
BudGT is offline   Reply With Quote
Old 04-04-2007   #8 (permalink)
remounting the brake fluid resevoir is kind tricky, took me awhile to figure it out. i ran the stock clutch cable for a year or so after the conversion and i finally broke down and had one made, i just couldn't stand too see the cable so contorted, i also used a set of the renthal streetfighter bars in black and it looks great with the frame. if you guys wanna see some pics i'll throw them up tommorrow...
"when i let off the throttle it gets all squirrely, so, i just stay on the throttle.."
Joe275 is offline   Reply With Quote
Old 04-04-2007   #9 (permalink)
As mentioned above, the main reason for the change is comfort (ok, think it looks wicked too) - too many years of martial arts have left my elbows and wrists a touch on the 'tender' side! Fingers crossed it all goes to plan!!
Old 04-04-2007   #10 (permalink)
Where did you get you clutch cable made? Mine's not in the best shape, and I probably should replace it when I put on the new bars.
Considering LSL bar conversion.... Reppyboyo Triumph SuperSports 12 07-24-2007 04:47 PM
LSL Bar Conversion for S4 B02S4 Triumph SuperSports 10 07-02-2007 09:26 PM
LSL bar conversion fitted! Ninjaboy Triumph SuperSports 16 04-22-2007 03:18 PM
lsl bar conversion steve Triumph SuperSports 3 11-06-2006 08:29 AM
LSL bar conversion Joe275 Triumph SuperSports 22 10-15-2005 02:55 PM
