Old 03-30-2007   #1 (permalink)
Favorite Bike: 2003 TT600
dkurtz's Avatar
Is gas supposed to pour out of the fuel connectors when you take the tank off? How can I fix this? It looks like they are plastic.
dkurtz is offline   Reply With Quote
Old 03-30-2007   #2 (permalink)
The female connectors are plastic, the males should be aluminium. Some fuel should come out as the seal isn't 100% tight. However, it shouldn't pour out. Sometimes the spring vavle gets hung up and will allow fuel to escape from the female side so just watch for that.
The dealer will replace the plastic elbow fittings for free, there was a recall.
Also make sure your connectors go to the right place. If they are aluminum, it should be mixed, red-white and white-red.
-Jon
Jon916996748 is offline   Reply With Quote
Old 03-30-2007   #3 (permalink)
If the connectors haven't been replaced and are stock they are all plastic. The aluminum parts are fixes for the plastic ones that tend to break and not all people have made the switch. I recommend switching them if you plan on wrenching yourself from now on. There is some drainage if you haven't emptied the tank as per the instructions in the service manual.
Cotay is offline   Reply With Quote
Old 03-30-2007   #4 (permalink)
dkurtz's Avatar
OK, the male connectors are aluminum. So the silver goes with RED female and the red goes with WHITE female?
Old 03-31-2007   #5 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
Apparently so. I never noticed when I pulled the tank off either TT600, since I always did it by feel anyway.
Will
SponsorHouse profile
tank removal help please?!?!? jasonk Speed Triple Forum 12 09-14-2007 05:37 AM
Tank removal Nightterror The Rocket Science Forum 7 03-27-2007 05:25 PM
Tank Removal frizbee_dog Sprint Forum 0 09-25-2006 12:44 PM
Tank removal triplenutter Speed Triple Forum 2 01-22-2006 12:33 PM
Tank removal pineygroveshop Tiger Workshop 4 12-31-2005 07:03 AM
